A4 2.5 TDI Cabriolet No brakes and No turbo
boomkim1 Oct 10, 2012
  1. boomkim1
    boomkim1 New Member
    I have recently had my a4 cabriolets cam belt replaced, however, it appears that in the process, I have lost brakes servo assistance and turbo boost. Perhaps something has happened to the vacuum pump in the process. Do the vacuum pumps on the 2.5tdi fail completely? Is there a way of telling whether it is the pump at fault?
  2. adamss24
    adamss24 Well-Known Member
    4,584
    406
  3. murran
    murran Well-Known Member
    1,545
    39
    ah, take the pump off the back of the n/s head. i bet whoevers changed the cambelt has lost or broken the drive bit. as you need to remove it to fit the cam alignment tool when doing the belt!
    or as adam said theyve snapped the plastic hose.
    take it back to the garage and kick off as theyve caused this!
  4. boomkim1
    boomkim1 New Member
    I would not let the same garage touch it with a flag pole, been a bad experience overall. Shall check out the pipe and if not remove the pump. Will update on how I get on. Thanks for the advice.
