A4 2.0tfsi door sensor problem ?
Morgan46 Dec 14, 2013
  1. Morgan46
    Morgan46 Member
    34
    My car won't acknowledge that the door is closed so interior light stays on and electric mirrors and windows won't work from any switch on any door,it will acknowledge the rear doors are open/closed and the passenger one too but not drivers side ,I've checked the fuses they are all fine and the pin and lock are clean ?any ideas ?
  2. ChrisShepB7
    ChrisShepB7 Member
    62
    If its anything like my old mk4 golf it'll be the door lock module in the door.
  3. Morgan46
    Morgan46 Member
    34
    after looking at a few threads it looks like a micro switch problem inside the lock mechanism
  4. lynallbel
    lynallbel Active Member
    395
    Could be a broken wire in the rubber gaiter between the door and the A pillar.
  5. ChrisShepB7
    ChrisShepB7 Member
    62
    Yeah all the micro switches that tell the comfort control ecu if the door is locked, unlocked, shut or open are located in the door lock module, if your handy with a soldering iron I think you can repair them but it's a lot easier to just swap it for a new or known working item.
  6. Morgan46
    Morgan46 Member
    34
    think that's what I will do my mate works at Audi and gets things for me at his discount rate so will try that
  7. lynallbel
    395
    Have fun, i dont think i have ever changed a door latch/catch mech thats easy!
  8. Morgan46
    Morgan46 Member
    34
    I'm a windscreen fitter by trade so taking doors apart is to fit side glass is my speciality so shouldn't be too bad hopefully !
