A4 2.0TDI 140 Loads Of White Smoke
janzbro Oct 22, 2012
  1. janzbro
    janzbro New Member
    17
    Hi all, the A4 has started to smoke like its got 200 bensons on the go at once. Does not seem to loose any power and is fine driving but when it pulls up at lights etc its smoking like crazy, white blue smoke not dirty black and smells a a bit oily. Strange thing is it doesnt do it all the time, most of the time its fine with little or no smoke?..EGR valve sticking perhaps, what do you think?
  2. DarkShadow
    DarkShadow Member
    53
    I seem to have the same issues and it's only visible when the temperature starts to drop. Will be keeping a close eye on this thread and I'll try to upload a video later.
  3. twist123
    twist123 Member
    186
    EGR is usually black smoke.
  4. CHEZ
    CHEZ moderately amusing Supporter
    4,142
    817
    i would say turbo oil seals on the last legs!
  5. Chrisd1983
    Chrisd1983 Member
    51
    Whats your coolant levels like? Mine did the same, turned out the head was cracked!!
  6. twist123
    twist123 Member
    186
    If its only when its cold and engines cold thats just steam, if all the time white smoke sounds like head gasket or head (smoke may have a sweet smell to it, like antifreeze). White blue is usually rings or turbo seal.
  7. Custardsucker
    Custardsucker Member
    112
    If it smells of unburnt fuel and as you say it is whitish blue in colour it could be a sign of retarded injection timing and is sometimes referred to as a slight cool misfire. Could be a sensor giving incorrect reading and timing is retarding to quickly before engine is at correct temperature.
