A4 2.0T Coming off long service intervals...what oil type!
Molnboman Jul 9, 2012
  1. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    Hej
    I am coming off the long service interval scheduling and want to move to regular oil and filter changes. My local garage are insisting that I can use a fully synthetic oil ( eg Castrol ) instead of the recommended VW/Audi Longservice "arm and a leg" stuff which they recommend. Is this correct?
    Am sure this topic is up here somwehere, can someone please confirm or deny and send me a link to where I can obtain the info.
    Thanks in advance,
    A
    5 Litres of the VW/Audi longlife is nearly 100 quid up here!....shocking!
  2. chrisa4quat
    chrisa4quat Active Member
    970
    What a rip off. We sell it at £5 plus vat. Mine is set to time as distance and I use 5w30 still
  3. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    507 long life spec is less than £30 for 5 liters, audi use the 507 long life even on time/distance servicing now
  4. rizzini7
    rizzini7 Active Member VCDS Map User
    977
    153
    43
    Ive been using Comma in mine now switched to 5w40 was about £36 posted off ebay apart from i needed 8L
  5. pj123
    pj123 Member
    307
    13
    Just make sure your garage uses VW spec oil 505 spec for petrol, 507 for diesels
    Although audi recommend 5w30 you might want to consider 5w40, it is certainly considered better for the 1.8T engine in an S3, better for the turbo as it is not so thin. Something like Quantum platinum 5w40 costs about £25.
    If you want to stick with your original spec oil for just over £100 you could have enough oil for 5 oil changes...
    FULLY SYNTHETIC ENGINE OIL 5W/30 25 LTR AUDI 507 SPEC | eBay
    Buy yourself a filter and you'll be doing it yourself before you know it!
  6. Molnboman
    1,338
    193
    Thanks for all the replies....am pretty sure they are talking about Castrol Magnetec 5w40....they are convinced that this suitable for Petrol 2.0t's!....I looked on the Castrol website and they are recommeding:
    Time and distance srrvices:
    [TABLE="class: recommendations, width: 553"]
    [TR="class: row1 prodrow1"]
    [TH="class: tiername tiername1, align: left"]Best[/TH]
    [TD="class: recommendation, align: left"]EDGE Pro. LongLife III 5W-30[/TD]
    [TD="class: capacity, colspan: 2, align: left"](a)[/TD]
    [/TR]
    [TR="class: row1 prodrow2"]
    [TH="class: tiername tiername2, align: left"]Better[/TH]
    [TD="class: recommendation, align: left"]Magnatec Pro. OE 5W-40[/TD]
    [/TR]
    [/TABLE]
    and variable ( long life services 30k km's
    [/TR]
    [TD="class: recommendation, align: left"]Edge Longlife II 0W-30[/TD]
    [/TR]
    [/TABLE]
    What do you think?
    A
  7. hades-
    9,481
    646
    u really ment £5+ pre ltr
  8. mm707
    mm707 Member
    278
    castrol edge 5-30 £35 in asda for 4 litres
  9. chrisa4quat
    970
    Yes Bez per litre lol
  10. rizzini7
    977
    153
    43
    I considered the castrol from Asda seemed best price i found and a damn sight cheaper than some i came across. Apart from when Opieoils has sale on. Also depends on what mileage you do in a day? i went for the thicker as its only about 5 miles to work for me and the long life thin stuff seems to degrade quite quickly on short trips
