A4 2.0 TDi and a lot of black smoke!
S30AN M Jan 10, 2009
  1. S30AN M
    S30AN M New Member
    Could anyone shed any light on this problem please?
    Recently, my A4 has been very sluggish, low down in the revs it has no pull whatsoever, its just flat. Then when the revs build up a bit and the turbo kicks in it shoots a load of black smoke out the back then its away. I had it in to my local garage and he says it was the air flow meter. So he changed it but the problem is still there.... ? It's booked in again for Monday morning for him to have another look.
    Thanks in advance
  2. NHN
    29,295
    1,701
    Yeah & maybe he will knock of the charges for the mistaken diagnosis the time he spends on it now, these garages do take the piss tbh, they change parts that dont fix the problem & still charge, guess using independents is the issue for that as audi can have parts on shelf that can swap etc to find fault, you sure its not exhaust related when it heats up, I'm not an expert into exhausts but seems to be when the engine has warmed up it chucks out some **** maybe its burned of & then its ok?
  3. fjtwelve
    fjtwelve Moderator Staff Member Moderator
    770
    10
    Suspect the boost contol valve, its called the N75 on my engine but not sure about yours. A bright finish circular object sitting on the side of the turbo on mine, again not sure about yours.
  4. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    I'm assuming he's done a diag check with VCDS or similar??
