A4 18t started ticking over at 1400 revs help pls
Evosi Dec 7, 2012
  1. Evosi
    Evosi New Member
    Hi my 190 18t started ticking over yesterday morning at 1400 revs now doing it constantly
    i have plugged in works snap on solus diagnostic no codes present so have been advised its throttle position sensor
    i have priced this up there £400 don't want to miss diagnose
    stripped down housing the sensors all one with the housing cleaned refit still same
    phoned dealer there solution book it in for a plug in £105 thanks
    could this be connected to my temp sensor on dash still not working I recently replaced thermostat housing and temp sensor in lower pipe
    really enjoying this money pit NOT pls help thanks Si
  2. marktdisport
    marktdisport Active Member
    1,195
    15
    Get it scanned properly coolant temp sensor can cause revving up when starting, so it could be a simple cheap fix £20-30
  3. murran
    murran Well-Known Member
    1,545
    39
    did you check the actual values on the position sensor with the diagnostics?
    doubtful its that tbh.
    vac leak or pcv valve more likely if you have no fault codes.
  4. Evosi
    Evosi New Member
    Engine management light finally came on earlier hopefully not telling me I unplugged the throttle body gonna try me blue point diagnosis tool Monday then worset to worst dealer it is
