A4 1.9tdi
goders May 26, 2009
  1. goders
    goders New Member
    hi i have an Audi 1.9 tdi red eye AFN engine year 2000 (w-reg)
    iam have truble starting it from cold but when its runing its ok until its goes cold can anyone help. cheers:sorry:
  2. BILKO1
    BILKO1 Member
    301
    You need to check glow plug operation and look for air ingress in fuel system.
  3. goders
    goders New Member
    its had new glow plugs they working ok.
    will check air ingress in fuel system i will let you know i i get on thanks
  4. goders
    goders New Member
    no air geting in the fuel
  5. moschino
    moschino Member
    252
    Are you sure the car is supplying 12 Volts to the plugs? I had one that had corrosion between the plug and the electrical connection causing the plug not to work correctly.
    Is the resistance of the glow plugs should be less than 1 ohm?
    Jim.
