a4 1.9 awx b6 model cant get passed 68c
gazza711 Sep 23, 2013
  1. gazza711
    gazza711 New Member
    17
    Hi,Im a newbie.why does my engine perform its best at 68c.any hotter and it burns richer.
  2. demus
    demus Fire in the hole..
    355
    19
    Fuel temp sender on the way out, or bad connection, does it warm up and sit at 90 deg like it should?
  3. gazza711
    gazza711 New Member
    17
    Hi.wow what a quick response.im averaging 55mpg.i changed the thermostat for a higher temp one and the mpg went down to 40-45mpg.changed it back.sorted.
    blocked off the top of radiator today and mpg was dropping to 40-45mpg.
    I too have a tdi tuning box now.
    gav
  4. gazza711
    gazza711 New Member
    17
    oh and it always sits on 68c.when I blanked off the top of the rad,it hit 89c but burning rich.
  5. demus
    355
    19
    Prob tuning box over fuelling then.. dont trust the trip mpg computer either,..
  6. gazza711
    gazza711 New Member
    17
    Ye I agree.its how far you've got left trip.no average mpg.
    just installed box.problem has always been there from the start with regards to temp.
    the minute I removed the radiator blank(box of shreddies open out)en route home,the mileage went up again.
  7. stu_m
    stu_m Well-Known Member VCDS Map User
    1,440
    your wasting your time going by the DIS reading you need to do tank to tank fill ups and work out your MPG from there
    I would change your stat to one thats not opening early and check the temp sensor too
  8. gazza711
    gazza711 New Member
    17
    I only work out my mpg based on 20L fills.providing I use esso,i get 240 miles every time.and I know my dis is ****,but I know how it behaves.i did change the stat with one that opens later,and the dis was dropping faster and I only got 180miles on 20L.its more the case of everyone saying that 90c Is the most efficient,but I disagree with this engine and other diesels ive had.g
  9. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,196
    160
    Is the tuning box into the injector loom or the fuel temp sensor?
    When did you last change your water temp sensor located at the rear of the engine?
    What was the higher temp thermostat and does the orignal work and how old is it?
    If an engine is running cooler, the ecu puts in more fuel to compensate. It cannot be more efficient.
  10. Google44
    Google44 Member
    33
    This sounds interesting. I cannot get DIS to show 55 mpg ever. I also know it is not my driving as driving BMW 320 the same way I get 60 mpg. The 20L is around 4.37 gallons. I get around 180 miles at best on 80% motorway drive %20 town. My temp sits on 90 on display as well as on VSDC.
  11. SL11CKK
    SL11CKK Active Member
    694
    35
    I know its not related, but what about boost leaks? As this could also cause it to run lean, just have a quick boost leak test.
    I get my DIS to report around 43MPG average around town and on dual carriage I've got it to report 54-65MPG depending on how long I'm on the dual carriage. Also mines mapped and not a tuning box like yours and the coolant temp reads 90 degrees.
    My thermostat and coolant sensor were changed for genuine ones from TPS.
  12. Google44
    Google44 Member
    33
    I don't have anything installed. Just standard setup. Also, how do you do a quick boost leak test.
  13. gazza711
    gazza711 New Member
    17
    Hi,Im well chuffed I got vaggies(VAG enthusiasts)I can chat to and not troubleshooting mechanic rookies!
    BLACKQUAT-
    1.-its plugged into airbox sensor and one in fuel sensor.
    2.Never changed sensor
    3.-high temp stat was a 95c one(I think)
    4.not sure if I tested present one/might of
    When I changed thermo/the stat showed 90c and the car DIS gave me 25%less fuel and 0miles is absolute.Same thing happened when I blanked top of radiator.Both times I converted car back to normal setup.on next fill of 20L,the ecu/DIS resets itself with new distance calculation and admitingly I think I got 25% more the second time.Thus there wasn't a problem in the first place.
    This woulve happened with or without the box-positive on that.
    So,back to square 1.
    They say don't fix what aint broken.
    So,every time the engine gets hotter than 70c the DIS ****s itself.Maybe I should run it two fillup of 20L to get a better average.
    Is it
  14. gazza711
    gazza711 New Member
    17
    I don't have a mpg DIS,only a miles left to go.i work out my mileage on 20L and divide by 4.39(20L/4.546which is how many litres in a gallon)
    google44-what wheels you got?bmw 320?
    its a 2.0 and 2.0 VAG lumps only average 44-50.
    my motors got egr delete so **** on idle for fuel saving.
  15. AudiLeon
    2,196
    160
    First things first bud.
    Disconnect your tuning boxes, you don't want one connected to the fuel temp sensor or the MAF. The better ones are digital connected to the fuel rail.
    Secondly. Order a genuine water temp sensor. It feeds the ecu with water temp and the dash for your needles.
    Also order a genuine thermostat.
    What could be happening is, the water temp sensor could be giving a faulty reading, then you adjusting the water temp may actually bring it back to correct. The reading from your temp sensor may be different via the ecu than via the dash.
    The tuning resistor is making the engine think the fuel is hotter so it injects a larger amount.
  16. Google44
    Google44 Member
    33
    I've just done average of 41 mpg. Mine is Avant 1.9 TDI 2001. My temp on display matches what VCDS shows as per what is delivered to it from ECU. Thermostat and temp sensor must be OK then.
  17. AudiLeon
    2,196
    160
    Seems low though, the Mrs averages 50mpg in her AWX A6 estate. She rarely hangs about.
  18. stu_m
    1,440
    the missus gets a good 45-48 to and from work in varying traffic with a fair few roundabouts which is always stop start on them
    on a run I can easily get high 50's
  19. gazza711
    gazza711 New Member
    17
    hi BLACKQUAT,
    My bad.ive got a tdi tuning box which comes with two connectors.one for the fuel pressure and one for the airbox.its a pd engine as well.
    Ok,so research says ive nothing to lose by changing the temp sensor.would this improve my mpg?
    As well,my heat in the car don't get super hot,but when I blank or change thermo,its burning hot.mpg swallowed.
    why would they install a 75c thermo.is this possible.i have the awx engine,and some say the highest temp spec is >85c.
    so many questions now.
  20. gazza711
    gazza711 New Member
    17
    Hey stu_m,
    my car is the same.10% better with esso diesel.
    gav
  21. AudiLeon
    2,196
    160
    85c sounds right for a indicated 90c on the dash. If your temp sensor is failing, it will effect mpg. Honestly though, lose the tuning box till you can get a decent digital one.
    My advice is, replace the water temp sensor, thermostat and lose the tuning box.
