a4 1.8t s2000 air filter
audiholic ste Aug 25, 2013
  1. audiholic ste
    audiholic ste Member
    171
    25
    Hi I'm new to this and was wondering if anyone has used or if we could use a s2000 air filter on a a4 1.8t
  2. aragorn
    18,485
    855
    yeh i'm sure it could be made to fit :)
  3. audiholic ste
    171
    25
    Yeah but on a s3 8l it fits right on . No messing about . Straight swap .
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,162
    1,123
    The filters are cheaper enough to give it a go.
    Try it. :)
  5. Broonie
    Broonie Active Member
    154
    37
    I will whip the filter out my s2000 and try fit it to my tqs after work
  6. audiholic ste
    171
    25
    Cheers would be very helpful of u . It's better to know .
  7. Broonie
    154
    37
    It doesn't fit, turbo intake pipe is about 15-20mm too small in diameter
  8. Bradderz_1988
    3,958
    240
    Yeah as the S2000 is 3" ours has a 2.75", the S3 lads fit the s2000 one over the maf and it will just about hold it !! you could get a 180' silicone hose that goes from 2.75" ID to a 3" ID and remove the standard airbox and make a bracket like the k&n one that bolts to the maf fixing holes and pipe your pipe off the maf ???
  9. Broonie
    154
    37
    Yeah I don't see why that wouldn't work, reducers can be picked up cheap
  10. jbh
    jbh TDi lover
    1,412
    168
    wouldn't this just breath hot air from the engine bay?
  11. audiholic ste
    171
    25
    Cheers lads if all I need is a reducer ( got one somewhere ) I'll give it a go . Cheaper than k and n cone filter . Just want to make the old car a bit more sprightly . I can knock the brackets up at work .
