A4 1.8t Quattro B5 Springs?
GoomMatt Sep 18, 2011
  1. GoomMatt
    GoomMatt New Member
    Hey, I have the facelift (180bhp) 1.8t Quattro, from 99-01 and am having trouble getting original springs for the rear (lowered 30mm).
    Was wondering if the best bet would be to just buy a full set of after-market as they only seem to come in a set of 4.
    Any advice on which to buy/ not to buy?
  2. GoomMatt
    GoomMatt New Member
    Also links and/or pics would be awesome if possible :)
  3. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    Do you want aftermarket or just a set of standard springs?
    I'm removing my sports suspension from my B5 avant, your more than welcome to the rear springs.
  4. Broken Byzan
    13,235
    464
    They won't fit Scott as the TQS springs are modle specific.
    I had a similar issue and went aftermarket, although i was lucky enough to score a new set for under £80 deivered and they are not too low, just nice
  5. ScottD3
    15,161
    1,121
    Ahh kills that idea.
  6. GoomMatt
    GoomMatt New Member
    What make did you end up going for? I believe Eibach are supposed to be decent, but are looking more like £150-200.
  7. ScottD3
    15,161
    1,121
    Koni STR.T from Larkspeed at about £300
    http://www.larkspeed.com
  8. GoomMatt
    GoomMatt New Member
    Will these do the trick?
    H&R Lowering Springs / Spring Kit for Audi - larkspeed.comhey dont specify the exact model as such, i.e 1.8t. But they are quattro for the right age.....?
  9. aragorn
    17,884
    688
    forget the H&R's. They only sell one spring which covers all quattro models, which cant possibly be right and will probably result in serious reverse rake on a 1.8T
    I've got a Eibach kit on mine which gives factory ride quality and a nice drop.
    If you go Eibach make sure you order the springs for a car without Air Conditioning though, as the the ones listed for AC models arent right.
  10. GoomMatt
    GoomMatt New Member
    Ah ok, i was wondering with the Eibach. Was looking at them at the same time and they were the ones i was most likely going for. I just didnt know about the H&R due to the one spring fits all..
    Did you just put on the -30mm Eibach then? And do you know if they do any slightly lower? Not rediculous, just fancied a bit lower (say 40mm) if im having to go after-market anyway.
  11. aragorn
    17,884
    688
    They only do one height in their pro-kit range.
    IMO its a really nice height. I can take a more side-on shot tomorrow for you so you can see the height better?
  12. GoomMatt
    GoomMatt New Member
    Cool, i do agree. Mine was lowered 30mm standard as its the 180bhp facelift, but just thought i might look into just slightly lower. But a pic would be awesome as i've had the wrong springs on mine for a while due to one being cracked previously =/
  13. aragorn
    17,884
    688
    Its a good 20mm lower than the standard TQS height.
  14. aragorn
    17,884
    688
    Oh for completeness i measured the distance between the arch to the ground and it was 64cm all round.
    You can compare this with yours to get an idea of the lowering you'll get.
  15. adamss24
    adamss24 Well-Known Member
    4,551
    392
    Looks good that !
  16. Broken Byzan
    13,235
    464
  17. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    although mine is not quattro i had H&R race springs ride was quite harsh. i know have Eibach pro kit havent looked back TBH. nicer ride also
