A4 1.8T QS Facelift (2000) - OBD II Complaint?
alex-qts May 25, 2011
  1. alex-qts
    alex-qts Member
    59
    Hi Guys,
    Does anyone know if the facelift A4's made in 2000 are OBD II complaint, I have looked for the stickers and tried to work out the pin layouts but have had no joy in getting a straight answer, I have had vag-com working but am now trying to use a Bluetooth ELM 327 OBD II adapter with an Android app called Torque to no avail!
    I must have tried 15+ different software programs that "should be supported" but all I seem to get is a strange clicking coming from the dash area!!
    Its an A4 1.8T quattro sport with engine code AJL if this makes any difference.
    Thanks for any help!
    Alex
  2. AR-rkon
    AR-rkon Mod back in a "B" Staff Member Moderator Regional Rep Team V6 Team Silver Audi A6 Audi A4 Audi Avant Owner Group
    1,912
    164
    The A4-B5 Is a K line diagnostic, as such is not OBDII compliant (this was mad compulsory for petrols from 2001 and diesels from 2004). I also have an ELM327 interface (though mine is USB) and this will only access to "P" codes (ie: generic engine) and the battery voltage, No other live data can be viewed, and thats after forcing connection on partial support... AFAIK Unfortunately vag Com is the only "proper" tool that will give you the live data + ecu acess on the B5 (and some Hand held units like Omiscan/MTpro/etc at £2k+).
    Hope this helps
  3. alex-qts
    alex-qts Member
    59
    Thanks mate, not the news I was hoping for but im glad I know now! The amount of time I have spent messing around with cables and software thinking I was the problem, the laptop, the calbe... etc!
    Think I might turn my efforts into getting a decent small laptop and GOOD vag-com cable that works, I need to be able to view certain bits of data on the move!
    Alex
  4. Keyser Soze
    Keyser Soze Member
    78
    Regarding the cable, that is a must. I got me one and it worked with vcds once on my laptop today. The pc recognises the lead but steadfastly refuses to recognise the driver now so vcds now spits its dummy out. Not Happy :(
  5. AR-rkon
    1,912
    164
    ebay special Kev? if so, i had the same problem, turns out it was a duff driver. though if you want i can email you the driver i used... (which has it working again)
  6. Keyser Soze
    Keyser Soze Member
    78
    AHHHHH Rob you are a star!!!!!!!
    I was avoiding the too good to be true ebay 7.99 -8.99 specials from China & Hong Kong , paid £25. Looks like I've been trussed up like a turkey!!!!! :think:
    I've uninstalled & reinstalled VCDS, drivers, etc, etc, etc but still now joy. I'll PM you the email addy.
  7. aragorn
    18,022
    718
    The cheap leads are more or less all the same.
    The driver is just a pretty standard USB to Serial bridge, Windows 7 will typically find the driver automatically if you let it search online, rather than using the supplied CD.
  8. alex-qts
    alex-qts Member
    59
    when I had problems connecting to vag-com I found that changing the virtual serial port helped. for some reason it would only work on port 4 not the usual 1 or 2??
  9. fARQUARE
    fARQUARE Member
    228
    Ditto, vag com can only see ports 1-4 so you'll have to change it to one of them.
    I have a cheapy vag-com lead and a cheapy bluetooth adaptor which I use for torque and they both work fine with my '96 tdi.
    Sent from my U20i using Tapatalk
  10. alex-qts
    alex-qts Member
    59
  11. Keyser Soze
    Keyser Soze Member
    78
    Bugger it, I've taken the plunge and have ordered up a VCDS-Pro Ross Tech kit from Ilexa (Buy the official Ross-Tech VCDS / VAG-COM diagnostic tool in the ilexa web shop) which contains a true HEX + CAN USB interface, 2 x 2 Adaptor, 14 pin round LT Adaptor, 3M Usb extension lead. This will be delivered tomorrow. Also have an old P4 HP laptop with XP lying about so I'll use that specifically for the diagnostics.
  12. Keyser Soze
    Keyser Soze Member
    78
    It's just arrived now by special delivery. So now here comes the fun.......
