A4 1.8T 2WD to 4WD
K7ERG Nov 21, 2007
  1. K7ERG
    K7ERG Member
    372
    Is it possible to fit a rear subframe from a S4 onto a A4 1.8T FWD to make it 4WD? Is the floor pan the same on both models or totally different?
    Thanks Craig
  2. 4Ring Jelly
    4Ring Jelly Member
    41
    it would be way easier, and save you a lot of time, money, energy, and potential problems in the future to just sell your current a4 and buy one with quattro from the factory. most of the mods you have can probably be put onto the new car.
    dont waste your time doing it, just get one that already has quattro.
  3. Markey
    Markey Active Member
    2,175
    It would not just be the rear subframe its suspension, gearbox front subframe suspension its all different between the two cars, if you can get a smashed quattor cheap then maybe its worth it other than that i would not bother tbh.
  4. Siena
    Siena Active Member
    2,626
    On a B6 / B7 car, the floorpans are the same, the 4WD rear subframe bolts in place of the 2WD item.
    On a B5 car, not worth the grief.
  5. K7ERG
    K7ERG Member
    372
    thanks for the replies 2wd it will stay.
    Craig
