A4 1.8 Heaters
WHITEY_1 Feb 8, 2007
  1. WHITEY_1
    WHITEY_1 Member
    229
    Hi lads, just a quick question got an A4 1.8T on a 52 plate, I got told today that the heater vents are supposed to be lit up in red is this true as mine are just white day and night? Here is a pic.
  2. AndyMac
    9,832
    45
    Garbage
  3. G19Rjs
    G19Rjs Turbo lag
    mine do light up red, not mega bright but you do see it. its an 03 1.8tse.:blackrs4:
  4. golf
    golf ***** rent boy VCDS Map User
    1,556
    Diplomatic as ever Andy.
    Mine don't light up either, I have a 2001 model.
  5. Sinny71
    Sinny71 S55 LKS
    779
    I'm sure mine light up as well, a 2004 Avant. I'm curious now though???
  6. Sinny71
    Sinny71 S55 LKS
    779
    Yes they definitely do light up.
    Oh and its freezing out..!!
  7. WHITEY_1
    WHITEY_1 Member
    229
    Dam... Now i got 2 fix it so the other question is HOW? is there a fuse for them or somethink :uhm:
  8. WHITEY_1
    WHITEY_1 Member
    229
    thanks for the reply 2 lads
  9. Sinny71
    Sinny71 S55 LKS
    779
    There doesn't appear to be a fuse for them specifically. Are all 4 vents not lit up? It would be strange for all 4 bulbs to go at the same time thats all.
    Its maybe worth checking this wasn't a revision on later models or something first. But my car doesn't have the interior light pack so its not going to be that.
  10. AndyMac
    9,832
    45
    Mine definately don't and never have (late 01 B6), so it must be an option or a revision on later models.
  11. cadders
    cadders Member
    40
    I have an 03 plate and mine do light up red. I'm sure I read on another post some time ago that this feature was made standard at around the 03 plate time.
  12. Sinny71
    Sinny71 S55 LKS
    779
    That would explain it then and it'll save Whitey tearng his dash apart. Not sure if it can be retrofitted but I really wouldn't see the point.
  13. raca4
    raca4 New Member
    22
    Mines an 02 reg with the int Light pack and they do light up so must be a feature of that option.
  14. FrankG
    FrankG Member
    160
    My 01 and 04 avant had/have lights, but my 04 saloon didn't and when I made inquires about this at the dealers I was told Audi went through a cost saving exercise on some of its models, they dropped the chrome inner ashtrays, fold away cig lighter, and the battery cover that went inside the bonnet, there were others as well but I forgot them, so it might not be just a case of bulbs blow, you might have to fit the holders and wire looms etc.....I know its a nice fixture but I dont think it is worth all the hasle, why not just fit the ambient lights in the upper roof centre console, just as effective and a simple cheap install. Do a search on the forumn for a step bt step fitting instruction. Good Luck.
  15. a4sline190
    a4sline190 Member
    149
  16. tdiman
    tdiman TDIMAN
    Mines a B6 01 as well, noticed when I had the glove box out the passenger side has the lamp & cable but no feed to it, going to try and connect this weekend, will let you know how hopefully
