A3 tqs clutch help
bansheeboyo Feb 6, 2010
  1. bansheeboyo
    bansheeboyo Member
    201
    hi ,hows it going.
    Recently my clutch pedal has started playing up,when i lift of the clutch it takes a few seconds to spring up.
    what could be the problem?
    Are we talking new clutch ?if so dose tqs use a s3 clutch ?who makes decent clutch kits
    cheers scott
  2. Broken Byzan
    13,237
    465
    When ours did this it was the slave cylinder, absolute pain to change as its a box out job.
    The 6 speed TQS uses a 240mm clutch so a clutch meant for an S3 will bolt in no problems
  3. bansheeboyo
    bansheeboyo Member
    201
    thank you bryan,do you know what clutch i would need for a 5 speed ??? as will need to uprate it soon
  4. djdougalno1
    djdougalno1 Member
    189
    the quattro gearboxes all use the same clutch 240mm in the a3 s3 5 speed or 6 speed all the same
