A3-------toe/camber.........sportback
vw754 Nov 6, 2012
  1. vw754
    vw754 vorsprung Durch Technik
    2,329
    58
    Im having a new rear wishbone,my car is a sport model 5 door 2006, i lowered it and did a before and after check to see how low it sat.......it sat exactly 23mm lower than standard.
    My question is..........due to replacing the wishbone............what do i set my REAR camber to,and my toe to..........id like it as close to the factory setting as possible.
  2. martinivw
    martinivw :)
    442
    24
    I would take it somewhere that can do 4 wheel alignment , for only £50 ish you can have the rear camber/toe & front toe set as it should be ( or how you want it) EXACTLY with no messing, unless you have the correct equipment,
  3. vw754
    2,329
    58
    THANKS ! i had the four wheel alignment done 7 months ago ,car drive 100% in a straight line,and tyres (front have worn evenly,is it possible to have rear toe done only or will all 4 have to be done,also what is the setting for toe and camber?
  4. martinivw
    martinivw :)
    442
    24
    Unfortunately i don't know what factory settings are :( , a local garage to me uses Hunter 4wheel alignment equipment which has manufacturers settings stored in it I believe ,
    I need mine done too,
    I had TT Wishbone bushes installed today so hopefully i will get alignment done in the next few weeks ;)
