A3 TDi Boost Gauge - FITTING???
Indie_DSG Jun 18, 2009
  1. Indie_DSG
    Indie_DSG Member
    99
    Hi All,
    I have an A3 TDi 170 DSG and want to fit a mechanical Boost Gauge.
    I have the vent pod sorted and need advise on there to tap in to the boost Pressure pipe?
    Any ideas?
  2. evomaster3000
    evomaster3000 Member
    449
    There is no T off u can use, I drilled a hole in a bolt and using a rubber washer drilled a hole in a metal alloy boost hose after the intercooler and simply stuck my 5mm rubber hose on to that.
  3. Indie_DSG
    Indie_DSG Member
    99
    Cheers Evo,
    I'm goint to tap in to the rubber hose just before the EGR housing.
    Thats the best point according to Barry the Car Wizard.
    Merlin do a 5mm Tap off feed that fits in the hose.
    Pictures up soon.
  4. cus
    cus New Member
    19
    so there is no other way of doing this on the 2.0 tdi without having to tap into a pipe? thanks, marcus
  5. 2192dougl
    2192dougl New Member
    where did you get the boost gauge? I contacted awe who also do a vent boost gauge and they sed the was for 2.0 fsi (petrol) models only. p.s. do you have any photos. Sean
  6. cus
    cus New Member
    19
    thats mine fitted :) really easy to do in the end lol
  7. cus
    cus New Member
    19
    another shot..
  8. Dj_rgr
    Dj_rgr New Member
    Sorry for interrupting this thread, I was going to ask the same thing!!.. I fitted a defi boost gauge to my drivers side dash vent in the weekend and was unsure as to where to plumb the gauge pipe to, so I tapped it into the turbo actuator vacumn pipe as a temporary basis.
    i was going to post a question as where should it be connected as I know where on petrol cars but am unsure where on a 2.0 tdi engine.
    my gauge shows -6 bar on Tickover and goes up to 0 bar when you change gear when driven hard.
    looks like I will have to tap into this egr pipe as well then, does anyone know if there anywhere else that you can tap into for the gauge to work correctly.
  9. HEKTOR
    HEKTOR Member
    401
  10. Dj_rgr
    Dj_rgr New Member
  11. HEKTOR
    HEKTOR Member
    401
    No worries ;-)
  12. Mindak
    Mindak Active Member
    787
    130
    43
    Any pics of where people tapped into?
  13. Bigjohn_A3
    Bigjohn_A3 Member
    31
    I'm also looking to do this, I'm happy with the wiring side but does anyone have a picture of where they tapped in to?
  14. Mindak
    787
    130
    43
    Hi mate Iv been and done it now and had to tap into the main boost pipe at the front of the engine!
    There's no other way other than fitting an EGR delete kit!
    CoolAsIce and Bigjohn_A3 like this.
  15. Bigjohn_A3
    Bigjohn_A3 Member
    31
    Thanks Mindak, much more clear now.
  16. Mindak
    787
    130
    43
    No worries mate glad I could help!
  17. iamnotthestig
    iamnotthestig New Member
    27
    What's the gizzit called that you used to tap into the pipe?
  18. Mindak
    787
    130
    43
    I used an airline fitting and got an engineer to make me a nut to fit it, Iv got my whole pipe going spare now if interested!
  19. iamnotthestig
    27
    Ive got an A5 so it would only be fitting I'd be interested in
  20. winger
    winger Member
    73
    32
    you still got this spare mate? im interested if so
  21. Mindak
    787
    130
    43
    Yes I've still got the pipe with boost tap!
  22. Simon170TDI
    Simon170TDI Member
    62
    Installed mine the other night
    Bigjohn_A3 likes this.
