A3 tdi 1st / 2nd gear selection problem
davidelson Nov 26, 2007
  1. davidelson
    davidelson davidelson
    i have a problem engaging 1st and 2nd gears - the clutch when released stalls the engine
    the engine will engage reverse and 3rd upwards and will drive
    any thoughts
    someone has said there may be a cable adjustment or breakage to the lower ratio selector???
    thanks
    david
  2. simch
    simch Active Member
    2,028
    A bit more info fella, that makes not much sense! !
    What happened to cause this? Did it just start doing it, make a bang, do it while driving?
    You say it stalls when the clutch is released? Is this because the gearbox is locked up solid in these gears, (ie gbox failure) or because its not actually in 1st / 2nd, rather in 3rd or 4th, meaning it stalls as you aint giving it enought revs?
    Have you tried engaging "1st or 2nd" and rocking the car forward form outside, engine off, to see if it all turns over?
    bit more info would help us.
  3. sprout99
    sprout99 Member
    373
    it's a common fault on 6 speed box in cold weather. Synchromesh is not good
    on early 6 speeders
    does it get better or always bad?
