A3 TDI 170 - White Smoke
codfather14 Sep 21, 2011
  1. codfather14
    codfather14 New Member
    Hi All,
    I have an A3 sportback 2L TDI 170 2007. Intermitantly I get white smoke when idling at the lights. The exhaust fumes seem to smell rich and not like normal smoke if that makes sense. When I put my footdown it can momenterally lose power but once warm it seems to be fine. When i shut the power off and put my foot back down it seems to do it more often but again when warm its fine. I have had it plugged in and there ar no fault codes showing. I have been told it could be the EGR Valve? Hoping it wasnt the turbo...
    Any help would be much appriciated
    Cheers Dave
  2. phil76
    phil76 Active Member
    572
    40
    White smoke is normally water,condensation,that could be in fuel or in exhaust etc,if its pale grey smoke on tick over which clears when revved then goes back the same on tick over it could be the turbo,but with out someone properly looking at it these are all just guess work,i cant see it been the turbo or water in the fuel though on a 170,EGR i have never seen one which is suffering with the issues to know what the symptoms are.
  3. retroted
    retroted New Member
    13
    Is the car loosing any coolant ?
  4. M88UES
    M88UES Theres Never Enough Power
    60
    I have this problem with mine, and a shakey idle. but my coolant level is normal. Gettin peee'd off with these problems now. only gt 70k on the clock nd seems all these 170's r fallen apart. surely audi should know about this!!
    My 170 stinks of something rich, def not diesel. only had my car a few months and had injectors done then it started with a shakey idle. but always had the smelly white smoke just not noticed it as much till now.
  5. Sidhu88
    Sidhu88 Active Member
    808
    76
    I too have this exact same problem. Struggles to start most mornings as well as the smokey idle. Seems to be a little low on power too. From what the guy i bought it from said, its a DPF problem, the car isn't regenerating, he reckoned it needed a force regen, but theres not a massive amount of info about that. The DPF has been replaced once already at the cost of just under 2 grand. I'm not forking out that sorta money, if i find out for sure this is the problem its gonna be removed. I've noticed my batteries not quite upto scratch either. I only get the smoke after the engine has gone completely cold, not just in the mornings. I do however get the overpowering smell, it comes into the cabin aswell even with all the windows closed. Even when fully warm and idling its always there with or without the smoke. The cars going for a service soon so i wana see what audi say, I'm planning to check over and the clean the EGR and i don't know if its possible on this but i may do an EGR delete and see how that works out. If the EGR is causing problems im assuming its putting additional oil into the combustion chambers hence the smoke.
  6. M88UES
    60
    be sure to post the outcome please Sidhu88, so all of us can get an idea of what it could be since we have same faults.
  7. mike foster
    3,967
    White smoke usually indicates water/coolant in the oil. When you remove the oil filler cap is there any sort of milky emulsion type liquid ?
  8. M88UES
    60
    Checked oil and coolant today . Oil is black and normal . Coolant level normal. Could it be turbo seal a can smell . Although no white smoke when i started it up tday.
  9. M88UES
    60
    Checked yesterday Mike and no milky emulsion just black as normal. Its hard to describe the smell its like burning rubber but couldnt be 100% on that. Ive still got the car under warranty and been in a few days back for a new AUX belt because had a bit of a stuttery start up. Going to have to ask them to look at it again for this smell and constant white smoke, surely the garage seen this when they were testing it on start up. Sick of bothering garages to get it looked at it but if its a serious problem i dont want to be paying for it since i only bought the car 1 month ago.
  10. MyMateDaveDJ
    MyMateDaveDJ New Member
    22
    Brought a 2007 170 TDI Quattro on Friday and noticed this issue as soon as I got it home :(
    Lots of exhaust fumes on startup, regardless of the weather outside. No fumes at all when driving, only when idle.
    Turbo is also very whiney now so Im wondering if thats related.
    Its my first TDI so I can't say for sure if theres any affect on power, it's driving fine but Im not pushing properly until I can find out more info on this.
    Has anyone had any info after getting Audi to diagnose, or any update on this??
  11. immo
    immo Stop me
    275
    40
    No smoke from mine but it does stink when stationary. A very rich potent smell
  12. evildream
    evildream New Member
    14
    Just found out this post.
    I also brought a 2.0 TDI 170 from 2007 a few months ago.
    Is the exhaust strong/acrid smell (no smoke) when on idle normal on this engine - I've had other diesels? I've searched a lot but no conclusions or fixes.
    I've spoken with other people with same engine and DPF delete and they say smells the same or worst so I assume it's not DPF related...
