A3 TDi 130 Quattro - what to look for?!?
Cossie_boy Mar 30, 2007
  1. Cossie_boy
    Cossie_boy Member
    472
    Hi all
    Im new to the site and am going to look at an A3 TDi Quattro at the weekend, its an 02 plate.
    Is there anything I should look out for as its only got a short MOT
    I have Golf MK4 GT TDi 110 and currently have a Bora SE TDi 115 so am kinda familiar with the engines etc...
    Do the A3's suffer from rear subframe bushes going and other Golf traits?!?
    Thanks in advance for any info
    Dave :cool:
  2. Cossie_boy
    Cossie_boy Member
    472
    Anyone?!?
    The actual car I was going to look at fell through!
    So im still searching again now, any tips on things to look for would be good!
    Dave
  3. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    Dave,
    Check it's had the cambelt & water pump done at 60,000 - if not it'll set you back around £350 ish to sort out, full service history is nice but not crucial as the engines are generally very strong if maintained properly.
    Other than that, the condition is the general giveaway of how the car's ben treated - i always look down the gaps between the panels for little bits of wax / polish etc as i think it shows the owner looks after the car well.
    good luck with the search.
    Mike
  4. batwad
    batwad Member
    864
    The Haldex oil change at 20k intervals is about the only thing to check for over non-quattro cars. ARBs are a common one I believe; mine were done by the dealer as part of the sale. Everything should be screwed down tight; be suspicious of rattles and creaks.
  5. Cossie_boy
    Cossie_boy Member
    472
    I cant seem to find a any pics of nice 5 door ones on here? little help :ermm:
