A3 Sportback springs or Sline sPrings help
ruairi83 Mar 22, 2012
  1. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,699
    554
    ive got a 2009 a3 sportback tdi.
    Ive been offered 2009 a3 sportback tdi sline springs.
    whats the differnce in ride height?
    would they be worth putting in and would they be hard than normal springs?
    thanks
  2. ruairi83
    1,699
    554
    anyone knwo about these?
    had someone say they drop 25mm... could this be true?
  3. ruairi83
    1,699
    554
    does anyone have an idea how much sline springs would drop the car? 10mm, 15mm, 20mm etc? someone must know...
  4. rOb_A
    rOb_A Active Member
    1,488
    hi depending on what spec of car you have, s line spring give a 25mm drop over the standard/se car. think they are 10mm lower than the sport spec. sure someone else will pitch in
  5. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,488
    Are you just lowering the car, or does ride quality matter.
    Not sure S-Lines are renowned for great ride.
    Think Blob's right ref ride heights
  6. ruairi83
    1,699
    554
    i just want it a bit lower but not too stiff lads.thanks for replys.
  7. Murley
    Murley Member
    56
    I believe the S-Line is a little lower than standard. The sport is stiffer than the standard as well so could only guess it's a little lower but nothing you can really notice (10mm?).
