A3 sportback inside rear lights
ferepe
guys,
is there any way using VAGCOM, how to enable rear fog lights to work as brake lights?
recently I enabled them to work as parking lights (so now all 4 are lit at the same grade; about 22% dimmed). they still work as normal fog lights (100% of power), but it would be nice to have them work as brake lights too (altogether with outer lights).
any suggestions/ideas?
Before you do anything I should check out The Road Vehicle Lighting Regulations 1989 which cover the lighting of cars etc because as I understand them you are only allowed to have two stop lights plus the high level brake light. You can have multiple red rear lights but only two stop lights. I assume it's to stop you blinding the driver behind you!
thanks for the note, I really didn't consider regulatory/legal side of that. Not sure about that, but normally (and as OEM fitted I guess fully legally) you have 2 high intensity stop lights + 1 high intensity rear door LED strip. That's more than two already. Some types as well (i.e. Volvo S40? Wagon uses same 2 outside lights and 2 inner lights for both parking/brake light). I don't know if it's legal here, but all these Volvos had the same configuration.
anyway, I'm not driving within the UK, so maybe I should check some local regulation to avoid problems.:angrymod:
I was just curious if there is a simple way to switch them (VAGCOM only, without re-wiring them). I found the parking light enabling option on a German forum and it was quite popular there, so I guess they took care about legal side of the thing too.
PS: just some more types with 4 rear lights enabled: Audi Q7, A6 wagon/alroad, new Seat Leon? and for sure a lot more
544
10
825
