A3 Sportback - 2010 8P3 S3 Facelift
MoAudi1.8T Jan 17, 2011
  1. ~RS~
    ~RS~ Active Member
    1,466
    22
    Sure is mate!
    I have found a good picture guide of retrofitting the headlamps and thinking about trying it myself. 2 things worried me, 1 location of blocks/ pins & wiring across from fusebox where feed comes in if they have explained correctly across to the CE.
    Is it hard to get the wiring across to the CE from fusebox entry? They didn't have any pics and I haven't a clue how it's feed from there to CE.
  2. Dean's A3
    Dean's A3 TDI S3 Hybrid
    252
    The only wiring done directly to my CE was the LED's from the headlights. Everything else was done under the bonnet. You have to bear in mind that pre-facelift headlights are 10 pin and facelift ones are 14 pin. I was not confident in doing this myself so I outsourced it to someone more competent.
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Hi,
    I read that the adapter 10 to 14 pin adapter kufatec do as seen in this link click me! takes care of any adaptions that maybe required under the bonnet for the headlights to connect up. Then it's a case of getting those 2 wires from harness into interior through bulkhead and wiring them into the CE and swapping out the old to upgraded CE.
    Maybe someone who done the work themselves, (cough Nige, cough Phil) can clarify this for us.
  4. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,405
    68
    lol
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i also dont have to rewire as i had adaptive bixenons anyway the converter plugs work but why pay for that then youre only repinning and running seperate wires
  6. ~RS~
    ~RS~ Active Member
    1,466
    22
    So it's not a good idea to use the adapters then? Not quite sure what you meant there... Is there a better way to do it?
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    just its cheaper to replug thats all youre like a fiver for two plugs and wire, you know the price for kufatecs loom
  8. NHN
    29,525
    1,766
    Its not quite a fiver trust me as repair wires arent that cheap these days, the cheapest is the 009 & thats £2 a pop & headlights dont use these type either, but even if kufa was cheaper, I still wouldnt use there gear.
  9. ~RS~
    ~RS~ Active Member
    1,466
    22
    I think for you guys it's easier as you have a clue wtf your doing, lmafao! But for an absolute newb like me I think it's easier to just get the loom made up or from kufatec.
    Is the F module a no no as I keep seeing these come up and haven't seen 1 K yet!
  10. NHN
    29,525
    1,766
    & how do you think we learnt then Rich :)
    Sometimes with parts you have to bite the bullet, personally I had to eat the cannonball.
  11. zedzo
    zedzo Member
    149
    eat the cannonball LOLLLLLLL
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i feel your pain nige should really start charging for all this info ;) f will not work without errors even though the lights will work, and like nige says youve gotta start somewhere it really isnt that bad, as for the wire nige, why dont you buy it in reels?
  13. NHN
    29,525
    1,766
    I do mate, I have reels, plenty of the buggers which is annoying for .5, .75, 1, 2, 3 mm etc for different loads & different colours, arrggh poxy wires lol, but the repair wires are still needed to attach to the reeled wire anyway chap for say running front to back, buying the pin ends & tools arent cheap either, the tool that is, pin ends is fun finding 1 supplier for them, but also attaching them can be a pita, but when got a chance will find a source for all, as would cut costs down & then also less soldering :)
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i know what you mean ive been looking for a good set of pin release tools as my kit they work on everything but the audi, what brand are you using pal?
  15. ~RS~
    ~RS~ Active Member
    1,466
    22
    Little bit of tweaking needed here and there but looks pretty good so far...
    Should have all tied up by next weekend... Mostly coding and wiring, slight adjustment needed to bonnet and finishing touches... S3 badge is coming off asap :no::Flush::undwech: lol
  16. Joereynolds89
    Joereynolds89 2010 Facelift!
    163
    looking VERY nice mate
  17. Lings
    Lings Active Member
    2,059
    31
    Looks good ,My misses said is that what we are doing lmfao shes hooked ...
  18. tcardio
    tcardio Well-Known Member
    992
    287
    your rear fender liner will look like this
    unless you buy two parts so it looks like this
  19. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers Joey :) Hope yours is sorted asap pal, will be great with the hybrid... my next move!
    Steve it's the only way I could have kept my car another year tbh mate, I've had it 2 years already and never held onto the same car for more than 18 months and the itch needed scratching, it was a must for me! Whatever happened to that great profile pic btw :hubbahubba: :p lol.
    tcardio, do you have a part number for those pieces mate, front splash/ arch covers are also required for anybody interested. I have the fronts and my S3 sills on order. As much as I hate to stick sills that say S3 on the car it looks like the only option! Will have to spray over the S3 me thinks..
  20. zedzo
    zedzo Member
    149
    looks great RS, post more pictures when its dun :)
  21. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    Looks wicked RS. more pics please!!:yum:
  22. ~RS~
    ~RS~ Active Member
    1,466
    22
    Will get some more pics when it's all sorted and lowered as it's still on stilts :haha:
  23. ~RS~
    ~RS~ Active Member
    1,466
    22
    Well I'm still on stilts, but funds are drying up for this project so I'll have to wait a bit before phase 2 - lowering, maybe more power :eyebrows: is initiated, lol. Here's a couple pics for those that were interested-
  24. S3RYE
    3,448
    70
  25. Ash B
    Ash B Well-Known Member
    5,831
    85
    Rich you already know my thoughts:wub:
    LOOKS SWEET, will look so much better lowered bet you cant wait to do it
  26. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers lads! Much appreciated, your right Ash can't wait to drop it!
    Lmao @ the yotube vid S3RYE :D Cheers mate
  27. zedzo
    zedzo Member
    149
    luks super, how did you sort the LED's in the end
