A3 Speed Pulse
imported_Gibbsy Feb 9, 2005
  1. imported_Gibbsy
    imported_Gibbsy Guest
    Tryin to install my Sat/nav system but need to find the VSS (Speed Pulse) wire anyone know where it is?
  2. imported_Gibbsy
    Also if anyone has installed an Alpine one that would be helpfull
  3. ajmackie
    ajmackie Member
    922
    it goes to your radio. search in the ice section for cruise control or vss or vehicle speed and you'll see a post from me and a reply from andymac telling where it is!
  4. richy
    richy Member
    892
    very precise responce there mackie! lol
    which car you installing it into?
  5. imported_Gibbsy
    going into an A3
  6. imported_Gibbsy
    And Aj did the search dont see the post ur talkin about.
  7. ajmackie
    ajmackie Member
    922
    lol Richy, was a rather vague unhelpful response now that I find out I can't find that post either!
    I've had a good hunt myself Gibbsy and you're right, it isn't there! It did have a pic from AndyMac so I'm wondering whether they have deleted it in their spring cleaning as the pic was prob hosted on audisport's server.
    Ok ...! Did you have a standard Audi stereo in your car to start off with? If you did then on the sticker it should say which it is.
    I can't remember which wire it is 100%, but it should be easy to find as 1 or 2 of the connectors are for the speakers, the other one is for the DIS and then i'm pretty much sure that the other connector houses the VSS signal along with the power connectors (best checking on that!). If you have a multimeter then you can check that the wire you think it is ain't going to do any harm (ie VSS wire should not be a continuous 12v!), the input to the stereo is probably protected anyways so should do no harm.
    So best thing to do is to have a look at the sticker on the head unit, which shows the wiring diagram. From memory of andymac's picture, the VSS connection is easy to see, if not take a pic and post it back on here.
    I'll have a search on bentley forum as pretty sure I read it on there too!
    Hope this reply is much more helpful than the first vague one!!!!
    P.S. It's snowing and I'm in work!
  8. ajmackie
    ajmackie Member
    922
    Think it is White/Blue !
  9. ajmackie
    ajmackie Member
    922
    just to further help you, someone in the A4 B5 section has just installed sat nav and says he has the pin outs. might be worth asking em
