A3 SB 2.0 TDi something running when car off, hot, smell...normal?
MiT Apr 9, 2013
  1. MiT
    MiT Work Hard, Play harder!!
    270
    19
    So i have my new A3 SB 2.0 S-Line, i have done less then 50 miles (i think) so far, but i have noticed when the car is switched off something is still running (radiator fan i guess) and i can smell something, and it is hot under the bonnet. Smells like something hot is burning something or when something gets heating. hard to describe.
    Water is full to the max level.
    temperature on the gauge is 90 degree.
    Is this normal? (never had a new car before)
    Just wondering something is not as it should be.
  2. Audi Man Dan
    Audi Man Dan Member
    55
    9
    Hi Mit, this is the engine cooling fan after a regeneration cycle that stays on to cool down the DPF.
  3. Audi Man Dan
    Audi Man Dan Member
    55
    9
    Perfectly normal, usually will only come on after a shorter journey. Mine is 4 months old now, had the same concern myself.
  4. Sootchucker
    Sootchucker Member
    101
    9
    There will also be a bit on paint etc on hot surfaces like the exhaust manifold, turbo and block, that will burn off and "cure" over the first 100 miles or so. Perfectly normal.
  5. frazzeld
    frazzeld Member
    142
    21
    Mine was doing this until I gave it a good motorway run....hasn't done it since! "touch wood"
  6. Audi Man Dan
    Audi Man Dan Member
    55
    9
    A good blast on the motorway is advised with a diesel every 2 weeks. My particle filter light has only once lit up and the motorway run sorted it.
  7. MiT
    270
    19
    thanks
    makes sense for the smell
    good to here, hopefully after the few trips of the next few days should sort it out then.
    thanks all for your comments, makes me feel better :)
    Appreciate it.
  8. Trebuchet
    Trebuchet Member
    57
    10
    As above, as well as the short-term whiff you'll have whilst the exhaust us bedding in, you'll have the burning whiff from the particle filter regularly/permanently.
    diesel particulate filter (dpf) | AA
    MiT likes this.
