A3 S3 starts but stops
tomgunn Feb 16, 2009
  1. tomgunn
    tomgunn New Member
    Hi.. I have an audi 1.8T A3 S3 and it has suddenly come up with a fault... the car will start but stops straight away... a dashboard message says EPC warning.... half the dashboard lights are not working along with the fuel gauge... any ideas... had someone’s computer run a check and it says that there is a problem with the code ‘18058'... the cars 5 years old and has done around 60k... any ideas why this has happened?
    Cheers!
  2. jmohide
    jmohide Member
    134
    Hi there mate, think you may want the 8L forum is it is a 1.8T S3, someone in there should be able to help.
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    sounds like the immob is cutting in. I'd check the fuses 1st but it is know for the contacts on the back of the display cluster to go. You could try taking it out a bit & wiggle the multiplugs.
    To get at it you need to release the lever for steering wheel adjustment, pull the wheel out & down. Behind that is a panel that needs removed & this will reveal the 2 screws holding the cluster in.
  4. tomgunn
    tomgunn New Member
    Manythanks for that... I try... cheers!!
