A3 / S3 Sportback thule roof bars - no rails. My Pic.
Itguy Mar 13, 2014
  1. Itguy
    Itguy Well-Known Member
    1,130
    450
    I promised the forum a pic of this and forgot to upload.
    This is the thule wing bars, rapid fit feet and the Audi 8V foot pack. (Bars = 969 127cm, feet = 754, foot pack = 1708)
    You can buy locks optionally if you wish.
    RossR likes this.
  2. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,584
    1,178
    Does it all go on OK and no damage to the paintwork etc without the rails? Been considering getting some myself.
  3. Itguy
    1,130
    450
    They are perfect.
    Nice soft(ish) rubbers for the feet which are specially shaped for the contours of the roof. Rubberised coating on the foot pack which goes round the door pillars too.
    I'd only ever consider putting them on a clean car (or clean where the feet go) as if dirty I wouldn't want to risk silly rubbing of dirt into the paint.
    They took a bit of time to adjust correctly the first time but then they lock solid and will be very quick to take on and off next time. It's also a 1 person job too.
    It's the first time I've used a type like this and I'm very impressed at the quality of the feet and fittings etc. They've very good.
    keyser likes this.
  4. Croftj
    Croftj New Member
    23
    Hi they look great, where did you get them from? I need some to carry my bike!
  5. jongeddes
    jongeddes Member
    57
    10
    Are the bars on the right way round? Ive been looking at these and all the pics the wing seems to go the other way round. Might be wrong though. How are they when driving do you get any of the annoying whistle as I cans decide between these and the edge version.
  6. MatthewB
    MatthewB New Member
    15
    Yep, they're the wrong way around (as per the instructions, anyway). I've got the same bars but with the fixing pack for the integrated rails, and mine vary between fairly quiet and quite noisy, though it seems to be more dependent on cross-winds, etc., rather than the actual headwind generated by the direction of travel. I ended up taking them off until I specifically need them for something (whereas my plain old aerobars which I had on the previous car I just left on all the time).
    My noise problem might be solved if I play around with the rubber strips, so I wouldn't rely on the above. I was however disappointed that the Thule footpack doesn't make use of the holes in the integrated rails, which makes getting them on in the right position, and square across the car, a bit more difficult than it needs to be.
  7. jongeddes
    jongeddes Member
    57
    10
    Good to know, do they fit in the boot ok, Im torn as the edge one probably would but aren’t as wide so trying to decide which to go for. But guessing once they're on Id probably just leave them on anyway. Ive had the square bars before and they used to whistle like mad over 60mph. Our last car were more like the edge version and they were very quiet but you do loose a lot of space on the bar.
  8. MatthewB
    MatthewB New Member
    15
    You wouldn't get the wingbar (not edge) in the boot, not without sticking down either a seat or the through-load carrier if you have that.
  9. Itguy
    1,130
    450
    Damn it, I could have sworn I got them the right way round. Easy to swap over though.
    I haven't actually been out with them yet so can't comment on the noise but I suspect they will be silent once I've put the rubber strips in
  10. MatthewB
    MatthewB New Member
    15
    If it's any consolation I read the instructions about 5 times with a mindset of, "are you SURE that's the way round you want me to put them!?" I guess the noise comes from the resulting turbulence, so having the tapered end that way does make some sense, even if it's not entirely intuitive.
  11. jongeddes
    jongeddes Member
    57
    10
    Easy done, did you look at any others, if so what made you go for these. Really can't decide which to get.
  12. the_lecht_rocks
    the_lecht_rocks Well-Known Member
    704
    274
    No substitute for proper roof rails and the locking rail bars IMHO though.
  13. Itguy
    1,130
    450
    I agree ref the rails - just didn't want to spend any more on the car to be honest and I prefer the look without, and I only use these occasionally rather than all the time.
    Have just RE read the instructions and yes, I'm a numpty.
    I did look at the genuine audi ones but they (I think) are made by Thule too and are just more expensive. It also helps that my next door neighbour works for a local motor factors that sell all the Thule stuff and he got me staff discount on the set.
    I'd also had Thule bars before (MINI branded) on my mini and they were great.
  14. cemerson
    4,584
    1,178
    Same as an aerofoil then - that's the intuitive way around for me. The trailing edge is far far more important than the leading edge in terms of reducing turbulence/drag.
