A3/S3 seat problems
Vikz Dec 12, 2006
  1. Vikz
    Vikz Member
    92
    I have a 3 door A3 and my seats are loose and i don't seem to see where to tighten the up from?
    Everytime i go over speed bumps i feel it slightly move and also braking suddenly.
    anyone have the same problem?
    thanks,
  2. hamski
    hamski Member
    121
    I've had this. There are 4 allen bolts with square nuts holding the bottom of the seat to the sliders (technical term?). You can just access the two front with the seat fully back, and vice-versa for the back bolts
  3. Vikz
    Vikz Member
    92
    cheers mate, i'll have a look over the weekend.
  4. Vikz
    Vikz Member
    92
    well i had a look over the weekend and i have no idea where these allen bolts are...
    could anyone point me in the right direction please
  5. richh
    richh New Member
    27
    Vikz
    Just had a look at mine, I'm with you - no sign of them.
    Is your seat loose on the mountings, or the mountings loose on the chassis? Might help to narrow down what we are looking for.
    R
  6. Vikz
    Vikz Member
    92
    the seat is loose on the mountings i think
  7. ash_s3
    ash_s3 Active Member
    1,016
    if you slide your seat fully back, and look at the front of the seat you will see an allen bolt going through the slider rail things into the seat subframe, there should be one each side on the front of the seat and one each side on the rear, you can access the rear ones by sliding the seat fully forwards
    there is also bolts that hold the seat to the slider rails,these are underneath the seat and are very hard to get to, one of mine was missing when i bought my car and i replaced it with anouther bolt but it was hell of an awquard job, took about half an hour as you could only just get a spanner in and turn it about 10 degrees each time!! GRRRR!!! lol
    hope this helps
    Ash
  8. Vikz
    Vikz Member
    92
    cheers Ash, i will have a look before saturday as i've got a 400 mile round trip to make in the A3 and i'll end up throwing out the passenger seat coz of the noise!
  9. Vikz
    Vikz Member
    92
    ok i had a good look under both seats and can't find the allen bolts and i have to drive up to Manchester on Sunday with this damn creaking!
  10. dantheman1986
    dantheman1986 Member
    262
    maybe you cant find the bolts becuase there not there, hence why your seat is loose??
