A3 Quattro, Which axle new tyres?
smbaker Mar 1, 2011
  1. smbaker
    smbaker New Member
    Hi all,
    Just had two new tyres on my Quattro, just not sure whether they should be on the front or rear axle??:unsure:. At the moment they are on the rear and the front tread is down to 4mm.
  2. PilotAudi
    PilotAudi New Member
    2,352
    479
    This is always a debate. It used to be Quattro = 4 new tyres at a time but Audi are more relaxed now as long as you have a minimum of 4/5 mm on the other pair. I was advised as fronts wear marginally quicker I should put new pair on the front.
  3. Yaks
    Yaks Member
    181
    I'd put them on the front personally.
    With the Haldex system being FWD the vast majority of the time, then both steering and drive deserve the better grip.
  4. kite
    kite Member VCDS Map User
    677
    New tyres= rear always.
    When braking the weight of the car moves forward making the back end lighter, so less grip.
    So if you want your car to end up facing the wrong way put the new one's on the front...
  5. smbaker
    smbaker New Member
    Thanks for all the replies! It is interesting, a surprise to me too the rears have gone in 13500 miles!!! No I haven't been thrashing it; (yet)....... been driving like granny grunt; makes me wonder how long they would last if pushed hard.
  6. PilotAudi
    2,352
    479
    As you mention A3 Quattro I assume you mean a 170 Tdi... If that's the case what tyres were you running? We ran our last 170TdiQ for 23,000 before replacing any tyres and rears were still circa 2.5mm. We ran 225 Michelins on 18in standard (20 spoke rims).
  7. smbaker
    smbaker New Member
    Yes 170tdi............Tyres from factory Bridgestone Potenza 225/40/18.
  8. PilotAudi
    2,352
    479
    Not heard good things about Bridgestones. Bet our new one has them!! Sods law
  9. eddyd
    eddyd Member
    99
    Yes it comes with Bridgestones, got my 170 quattro in January. Car is brilliant apart from the tyres, I couldn't believe they could be so noisy even on smooth roads.
  10. Smoothie
    Smoothie Active Member
    1,431
