A3 Quattro hesitation on hard acceleration??? Audi can't find fault!!
A3 Tom Dec 13, 2012
  1. A3 Tom
    A3 Tom New Member
    If anyone can help I'd really appreciate it. I have a audi a3 Quattro 170 sport back when i brought it i had a dpf fault with turned out previous owner had had it removed but not deleted so i have since had it deleted from ecu and at same time i had it remapped to 210bhp! But since this it hesitates under hard acceleration happens in 3rd 4th 5th and 6th between 2 and 4 thousand revs. If you accelerate gently its ok. I have put it into audi they had it for 2 days and can't find the fault. They have tried injectors, changed the fuel filter, and checked egr valve, and exhaust pressure sensor. Thanks in advance for any help.
  2. mjr901
    mjr901 Parts Manager - (Main Dealer) Gold Supporter Audi S3 Audi Main Dealer
    3,597
    1,067
    Who mapped it....?
    Sounds like wrong fuel, air etc values...?
  3. A3 Tom
    A3 Tom New Member
    It was a bloke in Northampton! He reckons his put the same map on a passat which is fine no problems.
    Before the remap it had a tiny bit of hesitation in 3rd but nowhere near as bad as it is now!
  4. DixonH
    DixonH Member
    31
    I agree i'd take it back and get him to do it again, it may need a little tinkering to get it right but it depends on if they know what they are doing or just loading a std map.
  5. audicruiser
    audicruiser Audi Heaven
    1,865
    If it was doing it before the map, then it's not the map at fault. All the map will do as you have found out is highlight the issue further due to the higher demands requested. As for the fault, it sounds like a sensor possibly throttle position as this would tell the ecu what is required amongst other things...
  6. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Have you had the injectors replaced?
  7. RedDejavu
    RedDejavu Well-Known Member
    1,801
    333
    cam follower checked?
  8. A3 Tom
    A3 Tom New Member
    Thanks for all the replies I think we have found the problem seems like it was already mapped before but a bad one. Then the new map on top off that made it worst. The tuner has now got me the original file and tuned that so fingers crossed! Thanks for you help.
  9. audicruiser
    1,865
    Dont believe that... I thought if you mapped it you replaced the hole file, not part of it.
  10. A3 Tom
    A3 Tom New Member
    Just come back from the blokes house. His took old file off and put new one on seems to have worked seems smooth again. So fingers crossed its fixed. Now time for a few mods :)
  11. Cossie_boy
    Cossie_boy Member
    472
    Its not blue reg starting MA by any chance is it?!
  12. A3 Tom
    A3 Tom New Member
    No it's lava grey reg starting ma??? Im interested why you ask?
  13. Cossie_boy
    Cossie_boy Member
    472
    Ah ok then, I thought you may have bought my old car as it had pretty much exactly what you are describing
