A3 problem that even the main dealer cant sort out
jimick Dec 6, 2012
  1. jimick
    jimick Member
    52
    [h=2]A3 problem that even the main dealer cant sort out[/h]
    Hi , looking for a bit of help here from anyone who might have experienced something similar with there Audi. I bought my third A3 from Arnold clark and after a week discovered on turning left on low speeds a rubbing sound coming from the off side front wheel area. The car has been into Arnold clark an amazing 8 times about this they have done a wheel bearing cleaned up brake calipers and put copper grease on them to no avail . After a heated visit to the service manager at the garage they agreed only the main dealer could fix it but after two days with Audi they havent managed to get to the bottom of the problem and advised to let the fault develop so that they can identify it when its totally knackered!Any help would be welcomed as im at the end of my tether wih this many thank
  2. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    Couple of things.
    Brake caliper dust/heat shield and, this may sound silly, but check the windscreen washer bottle is not low in water.
  3. Rick @ Unicorn Motor Dev.
    Rick @ Unicorn Motor Dev. Site Sponsor Site Sponsor
    1,271
    611
    Where are you based? If you're local we'd be happy to check it out :)
  4. jimick
    jimick Member
    52
    Arnold clark cleaned up the brakes and calipers and have adjusted the heat plate , washer bottle is full the next stage we are at is getting the caliper , disk and pads changed if this doesnt work ive no idea !
  5. jimick
    jimick Member
    52
    Thanks bud but im in Glasgow
  6. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Okay here me out, this will sound Bizarre but try checking the engine cover - the big plastic cover under the bonet.
    Mine was making a noise the other week after it had being returned from Audi, I thought :wtf:its just been in to Audi...
    Looked under the bonnet and they hadn't clipped the cover down correctly :S Not too sure what it was catching on but when i full locked left it made a rubbing noise.
    Hope this resolves the issue, and if not sorry for getting you out in the cold :D
  7. jimick
    jimick Member
    52
    cheers bud , getting out in the cold isnt a prob if it sorts this issue out honestly its getting like chineese torture
  8. Rhyso
    Rhyso Well-Known Member
    1,524
    317
    Steering rack? Anti-roll bar bushes??
  9. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    Bearing on top of the suspension mount? My front passenger side one was making a knocking/pinging noise at low speed (when parking etc). Audi sorted it with a new bearing.
  10. jimick
    jimick Member
    52
    Have you had problems with these , the noise is like a rub which is not continuous when turning left ?
  11. phil76
    phil76 Active Member
    572
    40
    Is it rotational ? if it makes a rubbing noise when turning left does it increase with noise or get quicker ?
  12. jimick
    jimick Member
    52
    Yip its rotational , sounds more like a rubbing noise it does increase on speed variation but it is more noticeable when driving away from a parked position turning left . Thanks for any help you can give !
  13. jimick
    jimick Member
    52
    Sorry it gets quicker with speed ,increases in noise when done at low speed
  14. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Im guessing the engine cover was all OK ?
  15. jimick
    jimick Member
    52
    HI mate checked it out and it all seems tight !
  16. Rhyso
    1,524
    317
    no i was merely offering suggestions 😕
  17. murran
    murran Well-Known Member
    1,545
    39
    is there an anti viabration ring on the driveshaft? (looks like a dohnut halfway up the shaft) is that in place?
  18. j4yvw
    j4yvw Member
    50
    Try checking the CV joint rubber gaitor is making the noise. My dad's mazda 2 was making noises whilst turning, so jacked it up and checked the usual suspects and nothing until put it on full lock and turnd it and fount the gaitor was the issue.
  19. murran
    1,545
    39
    ^^ could be. on full lock the folds in the gaitor contact each other and can make a creeking/squeeking noise. doubt youd be able to hear it in the cabin with the windows shut?
  20. jimick
    jimick Member
    52
    what is the anti vibration ring ? Its not something that has been mentioned by anyone who has looked at the car. The sound is like a hard rubbing noise and you can feel it slightly through the steering wheel.
  21. taylorc
    taylorc Ex S3 Owner - Now Waiting For A4 BE
    134
    Suspension bearings, there is a technical bulletin regarding these (I had mine done not long ago).
  22. jimick
    jimick Member
    52
    Honestly , what car did you have it done on ? and what year ? The problem with mine has ment the car spending two days at audi and no one there mentioned anything about this
  23. jimick
    jimick Member
    52
    Just had wheel bearing ,brake disks , pads and caliper changed and guess what no difference :banghead: Please someone out there must know something about this !!!!!! HEEEEEEEPL
  24. jimick
    jimick Member
    52
    Dont think it would be this as the noise is rotational noticed more driving slow
  25. jimick
    jimick Member
    52
    Hi mate there is nothing on the shaft like a donut ?
