A3 on S-Line Suspension dealer locator
oufc1976 Feb 16, 2014
  1. oufc1976
    oufc1976 Member
    237
    82
    Anyone know of a dealer that currently has an A3 (any model) running on S-Line suspension?
    I've not found one in the Oxfordshire/Gloucestershire area.
    Anyone with S-Line suspension live near Witney, Oxfordshire and wouldn't object to taking me for a spin in it?
  2. Itguy
    Itguy Well-Known Member
    1,130
    449
    Isn't the s-line suspension the same as s3 suspension?
  3. oufc1976
    oufc1976 Member
    237
    82
    Not sure to be honest. Don't know much about the S3. If it is that makes it easier.
  4. oufc1976
    oufc1976 Member
    237
    82
    From Audi site...
    "The Audi S3 Sportback’s special sports suspension means the ride height is lowered by 25mm compared to the A3. The springs and dampers are tuned for sportier handling to complement perfectly Audi’s legendary quattro all-wheel-drive."
    That suggests in terms of ride height it is the same as S-Line. Which at least gives me something to go on in terms of aesthetics. And gives me some confidence that it's a 'safe' choice
  5. h5djr
    9,181
    1,576
    The S3 certainly has the same 25mm lowered suspension and 18" wheels and 225/40 tyres as the S-Line Sports suspension but whether is it the same I wouldn't know.
  6. Itguy
    1,130
    449
    Well the s3 suspension drops the car 25mm over the SE suspension and 10mm from the sport suspension.
    From memory the s line suspension option is a 10mm drop over the sport suspension too.
    So in total;
    SE - standard
    Sport -15mm
    S line -25mm
    S3 -25mm
    What I don't know is if the dampers are any different between them or if it is just the springs. I'll try and look at the parts guide.
  7. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,756
    I think the ride heights are the same, but thats it.
    S-line and S3 probably have different dampers and perhaps springs, they certainly ride differently.
  8. veeeight
    6,849
    4,756
    According to the Online Configurator:
    S3
    2UC - S Sports Suspension
    G06 - Front Shock Absorbtion
    UB5 - Rear Shock Absorbtion for Sports Design
    S-line (with S-line Sports Suspension Selected)
    2UG - S Line Sports Suspension
    G04 - Front Shock Absorbtion
    (no code given for rear shock absorption)
    S-line (with default Sports Suspension)
    2UC - Sports Suspension
    S-line (with Sports Suspension de-selected)
    2UA - Deselect Sports Suspension
    Answer: The S3 suspension is unique, and is not replicated on the S-line
    (for a fuller picture we would need photos of the boot sticker)
  9. grantDUBshaw
    grantDUBshaw Active Member
    240
    62
    I'm in birmingham and have a 3 door on s-line suspension? It is similar to my previous 2007 a3 sportback s-line in all honesty, abit bumpy bumpy on bumpy roads which you could understand , you don't bounce all over the shop though. On decent roads with no potholes roads and motorways, it's brilliant! Handling is great on it.
  10. oufc1976
    oufc1976 Member
    237
    82
    Thanks mate. I've currently got a '99 MkIV Golf GTi on 18s with very little rubber. It can't be harder than that can it??
  11. PembsA3
    PembsA3 Active Member
    276
    71
    I currently have a 2003 MKIV Golf V6 4 motion and before that a 2012 8P S line and 2000 Golf MKIV GTI... I would say both Golfs are significantly softer sprung that the 8P S line, and the 8V S line ( standard Sport suspension) that I have on order...
  12. oufc1976
    oufc1976 Member
    237
    82
    That's really good info. Current order is with standard sport suspension. My desire to take S-Line suspension is based purely on aesthetics. Given your experience, would you recommend sticking with the standard sport suspension?
  13. PembsA3
    276
    71
    Personally (and it is a personal preference...) I'm glad to be settling with the standard sport set up. I think it's a good compromise. I would have liked the S line set up but where we live my Golf even bottoms out occasionally so a 10mm lower suspension probably isn't a good idea, for me, and I don't think you would actually tell the difference visually.
  14. oufc1976
    oufc1976 Member
    237
    82
    Thanks for the response. Probably best to leave my order as is then with standard setup, as I'd be picking S-Line 'blind'
  15. grantDUBshaw
    240
    62
    Preferably the s-line does sit just perfect ! If you have a lot of crappy roads around you I wouldn't recommend having the s-line set up as when you do hit a big bump, you know about it! Having lowered cars previous to my last a3 sportback, i don't notice any difference :D one of those being a mk IV golf lowered on 17inch polished audi TT comps :) but if you really want to see if s-line is for you, always welcome to come for a spin in mine!
    oufc1976 likes this.
  16. oufc1976
    oufc1976 Member
    237
    82
    Were do you live mate?
  17. grantDUBshaw
    240
    62
    Birmingham!
  18. grantDUBshaw
    240
    62
    Just to show you how it sits on the 18's with s-line suspension :)
  19. oufc1976
    oufc1976 Member
    237
    82
    Thanks for these...just what I needed. In terms of visual appearance the difference to the Sport suspension is very subtle, and as aesthetics was the only reason I was keen on S-Line I think I'll leave the order as is and stick with standard Sport set-up.
    Cheers!
  20. steeve
    steeve Well-Known Member TeamMisano Team Ibis Audi S3
    2,684
    1,507
    Thank goodness for that, I was worried that there might be mass suicide............... or at least a raft of second hand S3's coming on the market.
    veeeight likes this.
  21. driver_tim
    driver_tim Active Member Team Daytona Audi A3
    317
    Here are a couple of my S-line on sport suspension for comparison:
  22. grantDUBshaw
    240
    62
    Atleast it's made your mind up for you ! Sorted
