A3 Idle issue, help needed
Crashlanding Oct 29, 2008
  1. Crashlanding
    Crashlanding Member
    43
    hello guys,
    i have a 1.6 A3 1998 model.
    low end revs are bouncing and can stall whilst slowing down. is this issue to do with the idle valve or something else?
    also what would the cost to rectify this?
    thanks in advanced
    Graham
  2. Clach
    Clach A3 - 1.8Ts
    971
    do a search mate, a common issue - air related so first check your air intake system
  3. Crashlanding
    Crashlanding Member
    43
    hmmm MAF?
    get somec arb cleaner on it? this may work!
    thanks
  4. Clach
    Clach A3 - 1.8Ts
    971
    Maf is possible, but could also be the air filter etc...best to look at the simple things first..
  5. AndyMac
    9,832
    46
    Could also be temp sender, is it worse or the same when the car is cold or hot?
  6. Crashlanding
    Crashlanding Member
    43
    TBO i havent noticed but my brother said its a begger to start in the cold
  7. AndyMac
    9,832
    46
    Temp sender would be the best place to start, sounds like it's giving the ECU duff info. The ECU will adjust the fuel/air mix based on this duff info, so stalling, bad starting and idling issues will result. A new one is only £20 from your dealer and is an easy DIY fit.
  8. Crashlanding
    Crashlanding Member
    43
    andy thats ace i fouind a new one on ebay for £12.50 would this be listed i the haynes manualas i have one!
  9. dot32
    dot32 Member
    Do you need to reset anything when replacing the temp sender?
