A3 Fuse box connectors - part numbers please
Avus Sportback Jul 20, 2013
  1. Avus Sportback
    Avus Sportback Member
    114
    Hello,
    Can someone please tell me which connector you need to buy so you can push a wire into the back side of the fuse box and then install another fuse, I need the connector part number for the Mini type and the normal ATO blade fuses.
    Can you buy a repair wire with one on each end, both Mini and ATO?
    Thanks in advance
  2. NHN
    29,300
    1,702
    It depends, what's the connection for?
  3. Sidhu88
    Sidhu88 Active Member
    808
    76
    Autoleads bsfdual
  4. Avus Sportback
    114
    The connections are required to refit my towbar harness to my new vehicle, I could not get them out of the old fuse box !!
    There is a red female spaded wire that splits into three for power to the three ATO fuses.
    There are three ATO 15 amp fuses and one Mini 5 Amp fuse, it's a genuine Audi 7pin kit.
    Its for the fuse box on the side of the dash when you open the drivers door.
  5. NHN
    29,300
    1,702
    You can remove existing, you need to slide the pink part of fusebox downwards & then use a very thin pick like tool to push the locking tabs on the pin ends inward so it releases the wires from the holes.
