A3 front bumper
spencerjoel Feb 29, 2004
  1. spencerjoel
    spencerjoel Member
    85
    had a little knock the other day, cracked the number plate and the front grille /ubbthreads/images/graemlins/frown.gif
    It seems that to replace the grille the front bumper needs to be removed but i cant really see how to remove it, aybody know the correct way to remove it so that i can also check for any other damage underneath?
    cheers
  2. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    [ QUOTE ]
    cheers
    [/ QUOTE ]
    Ok, first off jack the car up, remove the front wheels, and remove all the screws around the wheel arch/lining. about5 or 6 on each side.
    Underneath the front lip are 2 more screws. Remove them.
    Under the bonnet, at the front edge you will see 4 platic cap thingies. Push the centres out of them (they will fall so either catch them or be prepared to search for them later), the remove the caps by pulling them up and out.
    Now pull the bumper by the arches outwards from the body and then pull forwards off of the car.
    Easy as that /ubbthreads/images/graemlins/grin.gif
    If there is any damage you will see on the crash bar behind that.
    Rich
  3. spencerjoel
    spencerjoel Member
    85
    thanks mate, i'll get right to it, is this the only way to replace the front grill or can it be fitted from the front?
  4. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    This is the only way you can do it im afraid.
    Rich
  5. spencerjoel
    spencerjoel Member
    85
    thanks for your help rich, cheers mate. is it possible to do this taking one wheel at a time, removing the screws and replacing it or not?
  6. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    yep.. Only way you can do it really (sorry, forgot to say)
    No problem m8, anytime.
    Rich /ubbthreads/images/graemlins/beerchug.gif
  7. spencerjoel
    spencerjoel Member
    85
    cheers mate, btw just looked at your latest pics, nice car!!! /ubbthreads/images/graemlins/cool.gif
  8. RichA3Turbo
    5,089
    /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/beerchug.gif
