A3 esp and steering lights on after smash
dallo Apr 24, 2013
  1. dallo
    dallo Member
    140
    hi to all new to this forum and hope someone can help.i purchased an a3 with front end damaged bent chassis legs had it all straightened on car-o-liner jig back to within 1mm.when I got the car both esp and dynamic steering lights on.now the car is straight how can I get these off or will they go off on their own thanks.location notts/derby
  2. Chillout
    Chillout Active Member
    610
    50
    Have you driven the car as that lights will come up when the battery is disconnected and will clear once driven failing that you will need to have the car scanned.
  3. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Welcome mate.
    You can get these fault codes cleared by using VCDS which will result in the lights going off the dashboard. Although, they may just come back on when the car is driven if there is an under lying problem.
  4. dallo
    dallo Member
    140
    haven't driven the car yet battery was dead when I got the car so new one fitted.will the lights go off when driven?
  5. dallo
    dallo Member
    140
    seen I kit on amazon for £37 is it worth buying or shall I go to garage?
  6. Chillout
    610
    50
    Drive it and they will reset after hundred yards or so if not you have an issue
  7. dallo
    dallo Member
    140
    will try it and post back.
  8. leeds2592
    1,399
    222
    Yeh, if the battery's been dead, give it a drive first to see if the lights go. If they don't, best thing is to scan it to clear codes and see what fault codes are coming up.
    I wouldn't recommend the cheapo cables you can get off Amazon and eBay, but some garages that use proper VCDS can charge a lot for a 'diagnostics scan' which literally takes 5 mins. Stick a thread up on here and I'm sure somebody local, with VCDS, will help you out for a few beer tokens.
  9. dallo
    dallo Member
    140
    will give it a go
  10. dallo
    dallo Member
    140
    how far do I have to drive as no mot and it wont pass mot with lights on will it?
  11. Chillout
    610
    50
    Not far 30 meters or so
    amit87 likes this.
  12. amit87
    amit87 Active Member
    173
    78
    not very far, about 100yards as someone mentioned, I disconnected my battery and took off steering wheel etc etc and lights wer eon, drove literally 10m and they turned off.
  13. dallo
    dallo Member
    140
    your a star it worked only drove down my drive and they disappeared thought it was going to be more expense thanks.
  14. Chillout
    610
    50
    I was like o f#$k when I disconnected my battery and the lights came up too
  15. dallo
    dallo Member
    140
    thanks
