A3 engine swap advice please
A_Davison Mar 15, 2014
  1. A_Davison
    A_Davison New Member
    25
    So as the title suggests I need a new engine. I was travelling down the motorway when the engine died on me - timing belt tensioner gave up causing the belt to snap. Ive been quoted between 2 and 4000 to fix depending on what state the head is in so I intend to swap the engine.
    Its a 2004 2.0 fsi, non turbo with engine code AXW.
    Ive seen a couple on eBay and providing I get one with the same engine code will it be a straight swap?
    On a side note, depending on difficulty level.. this has the potential to become a project car! So how difficult would it be to fit a turbo engine? if any would fit?
    Thanks in advance
    Alex
  2. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    The swap should be plug&play.
    The conversion to turbo is doable but it would cost you a lot. You would need the turbo and the pipings, oil feed, new ecu and software, stronger internals, uprated clutch and maybe gearbox...
    sliced likes this.
  3. A_Davison
    25
    I was thinking more of buying the 2.0T engine rather than retro-fitting the turbo.. would it bolt right up? with only the ECU needing swapped out? Obviously an intercooler etc. would be required but do you think its more money than its worth?
  4. Johnny Bravo
    898
    70
    Presuming the fixing points match, you would still need new gearbox, drive shafts, new exhaust, new hubs, new suspension, bigger brakes and others :) Again, a lot of money.
