A3 Engine Coolant Sensor G62?
reptor245 Jan 11, 2009
  1. reptor245
    reptor245 Active Member
    1,168
    hey guys, ive run Vag-Com today and my 1.8T and it came up with
    16500/P0116/000278 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    Possible Symptoms
    [​IMG]Starting the engine when engine is warmish or warm, idle rpm immediately is 1200 - 3000 rpm.
    [​IMG]Diesel: an indication is extreme long time burning time of the glow indication light.
    [​IMG]With all engine temperatures seldom idle rpm will vary between 900 - 1000 rpm.
    [​IMG]With engine warm (90 °C) the engine temperature suddenly drops (70 °C) and slowly comes back to 90 °C.
    Possible Causes
    [​IMG]Wiring and/or connections faulty
    [​IMG]Engine Coolant Sensor (G62) faulty
    other than the stealers, were can i get a new green type sendor from? thanks in advance
  2. andyg0141
    andyg0141 New Member
    15
    you can get it from GSF or Eurocarparts but the delaers will prob only be about £20/£25 quid so i would go there and get the genuine part tbh!!
    Andy
  3. reptor245
    1,168
    aha oks, might give them a ring tomo to get a price incase. ive email GSF too :)
  4. beeitch
    beeitch Member
    66
    Easy to remove, and cheap to buy :D
  5. abdus
    abdus Top Gear VCDS Map User
    1,827
    murraysdirect.co.uk
  6. dantdi
    dantdi ...
    521
    Coolant Temp Sensor for 2004 2.0tdi is 35 quid from audi. Brought one b4 xmas
    hope this helps.
  7. reptor245
    1,168
    nice one. just got an email back and will cost
    A new temperature sensor is £12.77 plus a seal £0.56. We currently have stock available for immediate despatch. P&P [1st class recorded] is £3.16.
    bargain.
  8. kaos_king
    kaos_king New Member
    10
    Sorry to bring this back up.
    Mine is coming up with the same error - G62 Implausable Signal.
    Ive changed the sensor and still no luck - what else can i check? Mr_v suggested buying the whole housing as sometimes it can get cracked but i want to know if there are cheaper things i can check first? Cheers guys
  9. kaos_king
    10
    It turned out that it was a loose connection to the G62 sensor
  10. russelj80
    russelj80 New Member
    25
    where exactly is this sensor on the car? mine has gone too apparently. same fault code on the vagcom and everything!!
  11. Madeley
    Madeley Member VCDS Map User
    125
    Just above the gearbox on a coolant pipe.
  12. MickM
    MickM Member
    69
    Has anyone got a pic of where this sensor is, need to change mine in a couple hours.
  13. SiGainey
    SiGainey Member
    506
    9
    You really can't miss it. If you follow the top radiator hose back to where it splits into a Y pipe, it's just to the left of that in a coolant pipe. Single clip, undo the wiring connector and pull it out :)
  14. russelj80
    25
    photo would be nice! ive changed 2 sensors in that area and really struggling to see where this one goes!
  15. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    This is the best I can find on the web. This is looking at the engine side on, with the air box removed, from the passenger side.
  16. talentwalsh
    talentwalsh Member
    139
    Dont forget to release the pressure before changing to avoid wet socks!
  17. Welly
    10,696
    129
    lol, or a feckin hot face....
    I'd normally recommend doing it after the engine has completely cooled.
  18. russelj80
    25
    nice photo mate!! thanks. This could be promising!!
  19. Welly
    10,696
    129
    No worries. Looking at the photo, the TIP is on the right, and the battery on the left.
  20. russelj80
    25
    got the air box out just now thinking id see something more obvious. looking at the pic tho ive already changed that sensor. the one i have wouldnt fit that 4pin connection anyway. unless audi gave me the wrong sensor here i dunno? . . im only wanting a temp reading on my dashboard i assume it is just a sensor somewhere?
  21. Welly
    10,696
    129
    Its deffo that one dude. Must have the the wrong one..
  22. Dani_B19
    9,336
    391
    Ive just changed the same sensor but i think the cars air locked now.
    Can i remove the expansion tank lid and squeez the pipes or will that suck more air in?
  23. Welly
    10,696
    129
    No, that will help.
    Best thing is to leave the cap off and give the engine a rev to fast idle for a min or two. That has always cleared any air locks I've had.
  24. Dani_B19
    9,336
    391
    So i can leave the cap off and start the engine? fast idle been around 2500rpm?
  25. Welly
    10,696
    129
    Yep, have the heaters in the car on max temp and full whack as well.
  26. Dani_B19
    9,336
    391
    Goes outside to try now :), cheers welly.
  27. aragorn
    18,490
    855
    implausible signal can also be caused by a faulty thermostat.
  28. russelj80
    25
    ive changed the thermostat mate. so its either the sensor ive changed is faulty or the connection is faulty or even still, there is a problem with the dashboard itself!!?
  29. RIGZI
    RIGZI New Member
    27
    I was getting a regular 17704 code off the LG along with a (white) smokey exhaust and a few hot start problems which was solved by replacing the G62.
    I bought the sensor, clip and o-ring from ECP for £18 and thanx to welly for showing us where the sensor is located, it's taken about 2mins to replace. Happy now :)
  30. RIGZI
    RIGZI New Member
    27
    S3_NDJ likes this.
