A3 driver's door rattling when swung shut.
9099 Jan 20, 2010
  1. 9099
    9099 TDi? Liberties!
    121
    As the title says, my drivers door sounds like a bag of broken plates when swung shut.
    The electric window works perfectly, so it is safe to rule that out.
    What could it be?
    Views and opinions welcomed and appreciated.
  2. 9099
    121
    guys... please help. I am going to kent (car is at my aunts atm) tomorrow to sort a few bit on the car.
    would be nice to hear some suggestions. seems like if it aint an s3 its not worth reading about. please don't let that be the case. :)
  3. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,579
    1,493
    My driver's door used to rattle with a very similar, metalic-like, sound. It turned out to be one of the large bolts (16) that hold the side reinforcement bar (5) was lose - 1 minute later the noise was gone. See vagcat.com for a diagram of the door.
    Without actually removing the interior door card and checking it, it's difficult to diagnose it further though. Try checking the link above for a diagram of the door cards and how to take them off for further ideas.
  4. Westy
    Westy Well-Known Member
    17,443
    1,104
    Mine used to rattle too. I took the door card off and had a look and found loads of shards of glass sitting in the bottom of the door where the passenger side window had obviously been smashed in the past.
    You need to get the door card off and take a look mate.
  5. HTC
    HTC Active Member
    3,428
    9
    Mine squeaks like a weee little mousey. Squeak, squeak, squeak.
  6. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Just poke some cheese into the door as he's just hungry and wants his dinner!.
    Squeek gone in no time I'm sure.
  7. HTC
    HTC Active Member
    3,428
    9
    Now my doors smell of feet......poooeey!
  8. 9099
    121
    Guys... Thanks you all very much for the informative AND funny info. To say I am impressed is an understatement.
    I am leaving to go to kent now. I will post back once I have had the door card off and sorted the problem as found.
    No cheese required my door doesn't squeek... But if it did only the very best "m&s/tesco finest selection" will do for my mouse trap. LMAO.
  9. HTC
    HTC Active Member
    3,428
    9
    Did you know that mice can't actually eat cheese. It gives then diarrhoea. The best substance to catch one is grated chocolate.
    Every day is a school day :)
  10. ruairi83
    ruairi83 Well-Known Member Team Sepang quattro Audi A4 Black Edition
    1,650
    534
    il send you guide how to remove door card mate.
  11. Essflee
    Essflee Well-Known Member
    2,146
    67
    I would definately check the bolts at either end of the door first to check they are not loose, mine were which causes the side impact bars to rattle when you shut the door...
    I'd check here first before removing the door card...
  12. 9099
    121
    Solved... Turns out it was the side impact bar bolts... I didn't need to take the door card off after all.
    Thanks all.
    I also managed to run a full scan with vag-com; I now know that the car most probably needs a new central convenience module. That would explain the dodgy alarm/key remote and the ignition not disabling the alarm.
    Or does it?
