A3 concert questions
two
i'm looking to replace the stock amp/speakers and sub over time
and have a couple of questions?
1. what adaptor do i need to get rca output from the stock concert head unit..?
(is it CT29VW02 - http://www.connects2.com/c2search.aspx?catID=58)
2. where is the best place to place to run a power cable through the bulkhead?
(manual a3 8P model, 54 plate)
3. where is the best place to take the switch positive?
1. Yes
2. On the 8L it's the spare grommet up by the pollen filter (passenger side under the wiper scuttle, far right, next to the wing), not sure if the 8P has this. Or you could try going through the ECU cover as this normally drops down into the drivers footwell.
3. Switch positive for the HU or amp? Amp is easy it should be provided with the above adapter as a flying lead. HU - you need to wire one in as there are none on the loom.
can you recommend somewhere i can buy the connector on-line..?
