A3 Can Gateway Upgrade
gysse2004 Jun 20, 2012
  1. gysse2004
    gysse2004 New Member
    20
    As the title says, is it a big job to upgrade the gateway module in a 2006 TDI ?
    I an hoping it is just a new module and coding ?
    Best regards
    Peter
  2. Ash187
    7,495
    744
    not done it myself yet but feel free to be a ginuea pig :p
    i know there are a few old timers here that have done it... as with all control modules when changing them over expect something to go wrong with it. if your lucky it will work without issues otherwise you may need to rewire something.
    grainqey likes this.
  3. gysse2004
    20
    He he, i feel much safer right now. Must be someone in here who has some advice ?
    Peter
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    why are you upgrading it?, most retro's only need as far as the ce unit
  5. gysse2004
    20
    I want the Optical Parking System on the Rns-E - The commands will not be in the unit i have now, i guess..
    Peter
  6. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    remember you'll need the oem audi sensors and (i think) the new 193 led model rnse.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    thats what i thought, theres a thread best to search for it and ask nigel (nhn) for advice he can do the work for you also and is a decent bloke, why bother with the hassle when he can do it for you :)
  8. NHN
    29,351
    1,720
    You need the relevant one for your car, as there are start stop versions, but yes can be done.
  9. gysse2004
    20
    Thanks Nigel, could you share a little more info, i know you have done it ? Maybe a part number ?
    Peter
    Ps: Still waiting for a price from you !
  10. gysse2004
    20
    I would love Nigel to do i for me, exept i live in Denmark- pretty long drive..
  11. PH1L
    PH1L Gievf Buckets
    3,851
    40
    haha maybe he can meet you in italy ;)
  12. osiris
    osiris Member
    33
    Pardon the silly question, but what exactly is a CAN Gateway? I had a fault code when I upgraded my RNS-E and the CAN gateway needed to be coded to have a navigation unit.
  13. Troubs12
    Troubs12 Member
    92
    10
    The gateway is the control unit that allows communication between the different can networks on your vehicle. All controll units on the car are connected to it but are connected to different can networks for example engine, abs, airbag etc are connected to drivetrain can which runs at 500k if memory serves and infotainment, convienence etc run at 100k so without a gateway they can't talk to each other. The reason the gateway has to be coded when a new item ie navigation or oem parking is added is the unit needs to know its there in able to relay can messages to and from it. Without the gateway nothing would talk and the car would be dead seen a few wet ones in my time and it's not pretty especially when you show the customer that this little box has died and made their £25,000+ car a big paper weight sorry for the ramble hope some of it helped
  14. gysse2004
    20
    Anyone ?
  15. gysse2004
    20
    Ok, i was just looking through the gateway install list 1K0 907 530 G, and i have channel 10 in there, does this mean that
    i don't have to upgrade the gateway ?
    Peter
  16. gysse2004
    20
    Ok, so it is all done- not a big deal. Find the correct index, copy your old install list with screen copy in windows, unplug old gateway module ! plug in new module, paste your old install list and coding..thats it !
    Someone needs help, feel free to ask
    Peter
    Ps: I updated from G to AF, to get the optical parking system to work.
  17. NHN
    29,351
    1,720
    Thats not how you should code the gateway as boxes sometimes move locations, so a tick box for one feature may be in one position for one module, but it may move to a different tick box on a newer or older version module, so you are best advised to manually code it by selecting the features your car has, to recall this just take screen dumps of each byte of the module, so you know what its been coded for.
  18. gysse2004
    20
    Point taken Nigel, still not complicated !
  19. NHN
    29,351
    1,720
    Nobody said it was complicated, but its easy to cock it up with the method ill advised, people are quick to say jobs take 5 minutes, but in reality, taking screen dumps of current module coding, stripping it out, removing, refitting gateway, recoding new, road testing car, checking for errors, then refitting trims etc, DOES NOT TAKE 5 minutes, thats where the time goes when doing it properly, especially when working on other peoples cars, where there is no space for errors.
    AF module is for start/stop & regen braking.
  20. gysse2004
    20
    Start/Stop shouldn't matter, it works fine in my car.
  21. gysse2004
    20
  22. NHN
    29,351
    1,720
    I didnt say it would be a problem, it was merely an advice of type.
  23. tcardio
    tcardio Well-Known Member
    989
    285
    I have to agree it does not take 5 minutes BUT it just got easier with the newer gateways as long coding down to 3 selections now so just need to check boxes in the installation list. No more screen dumps
    NHN likes this.
