A3 "Aux-in"
Davidb67 Feb 6, 2008
  1. Davidb67
    Davidb67 Member
    152
    Had a courtesy A3 yesterday and gave the Aux-in a try with my iPod.
    Found it VERY quiet - checked the volume levels on the head unit which was about two-thirds, and my iPod volume was up around 80%...
    can anyone with a recent A3 (i.e. with the now-standard "aux-in" 3.5mm socket) confirm if this "normal".
  2. steveg9
    steveg9 Member
    180
    ahem.... haven't tried it yet. Will try and get to Maplin for a lead and let you know
  3. Mr_P
    Mr_P New Member
    24
    When did they add the aux-in, then? Mine was built in Oct/Nov 2007, so a bit miffed it wasn't included.
    Anyone know if it's available as something the dealers can add on (I've got the Symphony head unit) ?
  4. Amchlolor
    Amchlolor Active Member
    5,604
    Were you using the headphone-out socket on your i-pod (jack plug to jack plug) or multipin to jack plug?
  5. steveg9
    steveg9 Member
    180
    week 47/48 from recollection (thread somewhere else) - mine was 48 and here was where I first found out
  6. Amchlolor
    5,604
    Does the stereo have an 'AUX IN' volume setting?
    Not to be confused with the normal volume setting.
    I know BMW's stereos have this, as many people complain of low i-pod volumes.
    The standard setting appears to be -3, with most people finding +3 works fine.
    You access the 'AUX IN' volume setting by pressing the audio button.
    Perhaps the Audi has something similar?
    Maybe time to RTFM?
  7. Kontraband
    Kontraband Active Member
    2,008
    yeah, you need to wack up the aux level to full ... its 5 in mine (BM) I 'assume' the audi stereo has a similar setting?
  8. cooni
    cooni Member
    171
    you will find that "line level" volume on an ipod is up around 95% volume. i have a pocketdock aux-out adapter, plugging the ipod into mixing equipment using that i get a proper line level signal, but a similar level is achieved only up around 95% volume through the headphone jack.
    (the aux-out adapter pumps out line level audio regardless of the volume setting)
  9. Amchlolor
    5,604
    I believe Belkin do some sort of amplified aux-in connection too?
