A3 automatically locks
slizza786 Aug 20, 2013
  1. slizza786
    slizza786 Active Member VCDS Map User
    399
    27
    Whenever I unlock the car and it's idle for roughly 20 seconds the car automatically locks which gets abit annoying and my fear is if one day the keys are left inside the car and it automatically locks I'll be screwed. Is there a way to disable this or extend the timer?
  2. Yonner
    Yonner Member
    155
    I think there may be somat in vcds that can disable this , nhn may know what module will need modifying :)
  3. leeds2592
    leeds2592 When I grow up, I want a 964!
    1,399
    222
    Not sure if the timer can be extended but it can be disabled via VCDS.
  4. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    Just looked at my DIS and it can be changed in there I think. Doors - Lock menu, assuming this is for what you are talking about.
  5. slizza786
    399
    27
    Yh the doors just automatically lock. I'm not really sure with the terminology you guys are using, I'm still quite new to this sorry.
  6. Zak0123
    Zak0123 Active Member
    540
    77
    Pretty sure it disables the auto-lock if you open and close the door, meaning that you can't lock your keys inside unless you re-lock it.
    Lima likes this.
  7. slizza786
    399
    27
    It auto locks even with the trunk open
  8. essIII
    essIII Active Member
    285
    35
    In short VCDS is a cable\software combination that lets you plug your laptop into the car's ODB2 port and change some coding\settings.
    DIS is Driver Information System - the screen in the middle of your dash where you see MPG etc - there's some menu items that can be changed in there.
  9. Zak0123
    540
    77
    Ok, my bad.
  10. fangio
    fangio Well-Known Member
    1,520
    182
    It won't lock with the keys in. Try it with your spare key!
  11. slizza786
    399
    27
    Thank you for that. Am I able to change the auto lock through the DIS?
  12. essIII
    285
    35
    To be honest, I don't know! A3Kent suggested it's possible - try scrolling through the available options in the DIS using the buttons on the end of the indicator (or windscreen wiper) stalk. I imagine the ability to do this varies depending on the age of the car.
  13. A3Kent
    1,571
    249
    There is a Door then Lock setting in the DIS as I said before but i'm not sure whether this is for autolock when you reach a certain speed or whether it's for what you are talking about - worth testing.
  14. hades-
    9,482
    646
    so if you unlock your car open the door then close the door
    the car still locks ?
  15. Lima
    Lima AUSmotive.com
    396
    29
    I agree with this.
    However, if you unlock all the doors but only open the boot, I believe as soon as you close the boot all the doors will re-lock. So you could lock your keys in the boot, but if you open one of the main doors the car should remain unlocked until you either lock it yourself or hop in and drive off (assuming you have the lock doors in motion setting activated).
  16. slizza786
    399
    27
    Yh if I leave one of the doors open the car stays open but if I leave the trunk open with all the doors closed the car will lock. Even if one of the windows are open and all the doors are closed the car will auto lock after 20ish seconds and it's just really annoying to have to unlock it with the key again
  17. fangio
    1,520
    182
    It's there so if you accidentally unlock it with the remote (say from in the house) and don't enter it, it will re-lock to stop it getting nicked. You can unlock the boot alone with the middle button with the car locked, then the boot re-locks when you close it.
    A clever system if you ask me, especially if you have your hands full!
  18. Zak0123
    540
    77
    Also you cannot 'lock' the car with the drivers door open, but you CAN 'lock' the car with the passenger door open so that when its eventually closed the car locks itself fully (similar to the boot method), again very useful at times.. or not however you look at it! :think:
  19. G19rnt
    G19rnt Member
    We found this out the hard way my partner was setting up the pram placed her keys and mobile in the boot with the car unlocked she then closed the boot without realising and then it locked luckily she was at my mums and was able to wait on me finishing work
  20. craigynett
    craigynett Member
    294
    somebody i know unlocked their car, got in, put keys in ignition then realised he'd left his walet in the house so got out of the car & shut the door. The doors locked with his keys in the ignition & he only had the 1 key
  21. Beagles
    Beagles Member
    88
    Does the key have to be in the ignition? If I throw a key in the boot an close it it locks!
  22. fangio
    1,520
    182
    Then it's faulty!
    hendry10 likes this.
  23. MacrosTheBlack
    MacrosTheBlack Member
    212
    20
    Yep as people are saying when its working properly it will auto lock the doors, after about 30 seconds, if you have unlocked and then not opened any doors (excludes boot).
    On facelift models roughly 58 plate onwards you can change auto lock functions through the DIS by ticking or unticking options using the controls on the end of the wiper stalk.
    Older models like my 08 prefacelift you need to use VCDS.
    Also car should auto lock the doors once you start driving when you get to 15mph. This then helps prevent you getting car jacked at traffic lights etc.
    Good systems that make good sense to me!
  24. fangio
    1,520
    182
    Only if it's activated. Might have been disabled by a previous owner as mine was.
  25. slizza786
    399
    27
    I tested the car today. I unlocked it, went inside then closed the doors with the keys in my hand and after 10-15 seconds the car automatically locked! This is really worrying as I can confirm that leaving the keys in the car by accident after unlocking the car and having all the doors closed will lock the car
  26. craigynett
    craigynett Member
    294
    get a spare key done, if you don't want to pay for a new remote & programming just get a blade cut that will at allow you to unlock the door manually
  27. Zak0123
    540
    77
    This definitely doesn't happen on my 61 plate! What years yours?
  28. slizza786
    399
    27
  29. Zak0123
    540
    77
    Such a weird feature...
  30. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,762
    Zak0123 likes this.
  31. fangio
    1,520
    182
    Didn't happen on my 2004 or 2005.
  32. slizza786
    399
    27
    Does it have anything to do with the alarm buttons on the drivers door?
  33. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Thats to stop your alarm going off if you leave a moving object in the car i.e. dog or kids, you press it and lock the car and it disables the sensors inside
