A3 Autolights - is this right?
A3_Rider Oct 2, 2010
  1. A3_Rider
    A3_Rider Well-Known Member
    723
    255
    I have autolights, fitted from manufacturer and when I put it on O (off), the lights are very dim, but when I put it on auto or the 2nd option it turns the lights on (side lights I think its called? and then at night the xenons work fine.
    My question is; can the lights never be turned off? Seems to be 3 stages; dim lights, side lights and fully on.
    Not too good at technical terms for them but you get the dea:scared2:
  2. smudge_don
    smudge_don Active Member
    2,944
    If you have auto lights, there should be a stage between 0 and sidelights that says "auto"
    Should look like this:
    I think you're on about the DRL's (daytime running lights) which are always on. However you can change this by going into the car options if you have the RNSE or using VAGCOM
  3. paddy
    paddy Audi=No fault code, no idea
    5,184
    137
    Smudge
    He says "but when I put it on auto or the 2nd option it turns the lights on "
    Auto is the 2nd option so he has auto :) so should they glow dim in the off position ? well no, sounds like a bad earth to me but Nige is our electrics bod.
  4. smudge_don
    2,944
    He says that the sidelights come on, so either he doesn't have auto lights and therefore has a switch with 3 stages, or he is thinking that the DRL's are sidelights, which they're not
    In "auto" the DRL's are on all the time
  5. 8ig_steve
    8ig_steve Member
    39
    For info:-
    2010 Sportback with Adaptive Xenons
    In the off "0" position everything is off including DRLs, Auto does its own thing (a bit too sensitive for my liking, headlights are on far too soon), Side lights setting brings on DRLs only and Headlight setting turns on Head lights manually. No DRL dimmer or switch on the panel on my version though!
  6. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    A3 rider
    Please clarify what year your car is, this will help us to help you.
    It seems unclear at the moment what you have
  7. sub39h
    sub39h Active Member
    2,502
    take a photo of your headlight control panel
  8. A3_Rider
    723
    255
    Never had autolights or xenons before. I thought DRL was the height the lights would be at!
    Changed it to 0 and they go off now - what is the purpose of the DRL? Also what is that button below the DRL?
    I will read the manual in an hours time too lol:eyebrows:
  9. FranA3
    FranA3 FMDETAILING Regional Rep Site Sponsor Gold Supporter Audi A3 Team Brill Red
    7,235
    328
    drl is daytime running lights so you should have in position 0 no lights on in position 1 (on the drl switch ) drl if i think they are in the middle of the headlights looks like sidelights but brighter and if you turn sidelights on then the drl will go off so leaving just sidelights on and then zenon's on for the main headlights , the button below is for the coming home / leaving lights
  10. A3_Rider
    723
    255
    I was wondering about them as my friend has them on his R32 DIS and I couldn't see it on mine - thanks!
  11. Herman
    Herman New Member
    20
    AGREE. Anyway we can adjust its settings? To let it stay at its brightest at all times?
