A3 Alloy question
3DTDi Oct 18, 2011
  1. 3DTDi
    3DTDi Member
    239
    Hi chaps, have an 8P and want to fit some alloys from an a4, the wheels in question are pescaras but from the a4 not a3. Therefore they are 8j not 7.5j and have an offset of 48 however the a3 ones are 54? would these fit? and would then literally be 6mm further into the arch than the a3 variants?
    thanks in advance
    edd
  2. Ash B
    Ash B Well-Known Member
    5,831
    85
    Yes they will fit. I think they should stick out a bit more than your current alloys.
    But im sure one of the other guys will confirm all this for you :thumbsup:
  3. Ads
    Ads License to drive
    8,230
    612
    Those wheels will be fine. My wheels are 8.5J wide with an offset of ET45, so they are even wider and sit further out than the wheels you mention.
    And Ash says, the lower the offset the further the wheels will stick out.
    Something you need to think about are the tyres. Do the wheels come with tyres also??
    If so, check the tyre size because a lot of wheels off of other models come with the wrong size for an A3.
    My wheels are off of an A8 and came with huge 255/45 tyres so had to swap them for 225/40.
