I am a A3 2002 130BHP owner since a few weeks. The ESP light was on when i bought the car. A week later the blinker relais module was faulty and i replaced it with a new that i bought by the audi dealer.
At the same time i checked my fuses with the ignition on but motor off and since than i have a airbag light on on my dash.
I have bought in meantime a vagcom cable and i read out to see what the faults are.
Can somebody help me to clear the fault codes.
Here a read out of the vcds
Thursday,21,November,2013,22:24:07:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUZZZ8L23A003042 License Plate: 21112013
Mileage: 107690km-66915mi Repair Order:
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: WAUZZZ8L23A003042 Mileage: 107690km/66915miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 FT
Component: 1,9l R4 EDC G000SG 1527
Coding: 00002
Shop #: WSC 06435
VCID: 6ED328332A62DE6E76F-4A3A
WAUZZZ8L23A003042 AUZ7Z0B2092908
2 Faults Found:
17664 - Engine Coolant Temp Sensor (G62)
P1256 - 35-10 - Open or Short to Plus - Intermittent
18057 - Powertrain Data Bus
P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019970
Shop #: WSC 06435 000 00000
VCID: 2E53E833BAE29E6E36F-5000
2 Faults Found:
00778 - Steering Angle Sensor (G85)
003 - Mechanical Failure - Intermittent
008 - Implausible Signal
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 J
Component: A3 KLIMAAUTOMAT 0105
Coding: 00043
Shop #: WSC 06435
VCID: 2F6DF537EDE897663D9-254E
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 06435
VCID: 479DBD9765582F26159-5072
2 Faults Found:
00588 - Airbag Igniter; Driver Side (N95)
33-00 - Resistance Too Low
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
32-00 - Resistance Too High
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 932 D
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 04040
Shop #: WSC 00000
VCID: 3169F34FFBDC81962BD-5000
2 Faults Found:
01304 - Radio
49-00 - No Communications
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8D0 862 257 B
Component: ZV-Pumpe, Funk D16
Coding: 14913
Shop #: WSC 06435
VCID: 2C57E23BDCFEEC7E18B-4DD6
End ---------------------------------------------------------------------
Coding: 00002
Shop #: WSC 06435
2 Faults Found:
Coding: 0019970
2 Faults Found:
Coding: 00043
Shop #: WSC 06435
Coding: 00104
Shop #: WSC 06435
2 Faults Found:
Coding: 04040
Shop #: WSC 00000
2 Faults Found:
01304 - Radio
Coding: 14913
Shop #: WSC 06435
