a3 90hp using a 130hp turbo
aiidonevs Apr 30, 2007
  1. aiidonevs
    aiidonevs New Member
    Hello
    I'm a a3 owner from Portugal and have been wondering if i fit a 130hp turbo in my '96 1.9tdi 90bhp will make any difference? Or even if it is possible.
    BTW it allready has a box installed, so i guess it has about 115-120hp.
  2. inigoj
    inigoj Member
    263
    You could possibly get a 130 VNT turbo and manifold to fit your car, but the 90bhp models have a wastegate, with a totally different boost control system to the 110/130/150 variable vane turbo cars.
    You would also have to modify the boost control to get more pressure.
    A bigger turbo is only really required on a heavily modified engine, when higher PSI and cooler charge is needed, without the turbo having to work as hard.
    The best route to take with a 90 is larger injectors, and a remap to suit.
    A larger turbo, modified boost control and front mounted intercooler can be added afterwards if you want to push your engine even more.
  3. aiidonevs
    Hello.
    I asked this because I kind of have a good oportunity to buy a A3 130hp used turbo for 200€ (about 150£). But just fitting the turbo wont do much power on the car right? And it wouldn't fit perfectly would it? (sorry for the noob questions, but no auto expert here :|)
    I've also heard that since the car is too old i should change the noozles...
    The remap is also a solution i've been wondering.
    thanks
  4. 347
    347 Active Member Team Daytona VCDS Map User Audi S3 DSG
    362
    59
    hi ,
    your existing egr pipework will not fit on the 130 turbo manifold
    so you would have to buy the correct egr pipe , more expense , the mounting flanges are at different angles
