A3 (8P) problem with xenon range and other VAG errors HELP!!
bifixz Nov 19, 2012
  1. bifixz
    bifixz New Member
    Hi everyone,
    Greetings from Portugal. I'm having some problems with my Audi 8P BKD engine. For the last 2/3 weeks I get a message on the on board computer regarding the automatic range adjustment that wont let the car start. When this shows, the resistance light also stays on, the display panel shows 0 km on the fuel and the AC starts up real fast.
    Took the car to an official AUDI shop, 5 days later, still same problem and no resolution. Payed over 300€ and they said that the problem could be the ECU, but only 75% guarantee. So, pay over 1500€ to fit new one, and no 100% guarantees that would fix problem.
    Hooked up a VAG-COM cable, and this is is the result:
    VAG-COM Version: Release 704.1
    Data version: 20071016
    Monday,19,November,2012,09:55:01:59303
    Chassis Type: XXX
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 76 7D
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: Sporadic communication error 1000
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No SW: 03G 906 016 G HW: 028 101 136 4
    Component: R4 2,0L EDC 0000SG 5705
    Coding: 0000072
    Shop #: WSC 06435
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023174
    Shop #: WSC 06435
    1 Fault Found:
    01314 - Engine Control Module
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.LBL
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Address 09: Cent. Elect. Labels: 8P0-907-279.LBL
    Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
    Component: Bordnetz-SG 1.0 H29 0501
    Coding: 038A4F0082141000000000000000000000
    Shop #: WSC 00000
    Part No: 8P1 955 119
    Component: Wischer WWS Audi350 0130
    Coding: 16711696
    Shop #: WSC 00000
    1 Fault Found:
    Address 15: Airbags Labels: 8P0-959-655-84.LBL
    Part No SW: 8P0 959 655 F HW: 8P0 959 655 F
    Component: Airbag 8.4ED H01 0130
    Coding: 0010602
    Shop #: WSC 06435
    Address 16: Steering wheel Labels: 1K0-953-549.LBL
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenksäulenmodul 012 0030
    Coding: 0000012
    Shop #: WSC 06435
    Address 17: Instruments Labels: 8P0-920-xxx-17.LBL
    Part No SW: 8P0 920 930 F HW: 8P0 920 930 F
    Component: KOMBIINSTR. VDO H25 0110
    Coding: 0004103
    Shop #: WSC 00999
    Address 19: CAN Gateway Labels: 1K0-907-530.LBL
    Part No SW: 1K0 907 530 B HW: 1K0 907 951
    Component: Gateway H08 0090
    Coding: 7D0F0F42070100
    Shop #: WSC 06435
    1 Fault Found:
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 174
    Mileage: 157300 km
    Time Indication: 0
    Date: 2012.11.16
    Time: 10:02:02
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.LBL
    Part No: 8P0 959 801 A
    Component: Tuersteuerger. H10 0010
    Coding: 0000016
    Shop #: WSC 06435
    Address 44: Steering Assist Labels: 1Kx-909-14x.LBL
    Part No: 1K1 909 144 E
    Component: EPS_ZFLS Kl.10 1202
    1 Fault Found:
    Freeze Frame:
    Mileage: 7280 km
    Temperature: 27.0°C
    Voltage: 12.40 V
    Voltage: 12.10 V
    Address 46: Central Conv. Labels: 8P0-959-433.LBL
    Part No: 8P0 959 433
    Component: KSG H02 0040
    Coding: 108800186D288505484AC67000
    Shop #: WSC 06435
    Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Part No: 1K0 907 719
    Component: Neigungssensor 002 0002
    Part No: 8P0 951 177
    Component: Innenraumueberw.H03 0010
    Address 47: Sound System Labels: 8Px-035-382.LBL
    Part No SW: 8P3 035 382 HW: 8P3 035 382
    Component: AB2 SUBWOOFERBOXH23 0100
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.LBL
    Part No: 8P0 959 802 A
    Coding: 0000016
    Shop #: WSC 06435
    Address 55: Xenon Range Labels: 8P0-907-357.LBL
    Part No: 8P0 907 357 A
    Component: Dynamische LWR H01 0010
    Coding: 0000001
    Shop #: WSC 06435
    2 Faults Found:
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 157304 km
    Time Indication: 0
    Date: 2012.11.16
    Time: 10:02:01
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 40
    Mileage: 157304 km
    Time Indication: 0
    Date: 2012.11.16
    Time: 10:02:01
    Address 56: Radio Labels: None
    Part No SW: 8P0 035 186 HW: 8P0 035 186
    Component: concert II EU H53 0060
    Coding: 0001003
    Shop #: WSC 06435
    Address 76: Park Assist Labels: 8P0-919-283.LBL
    Part No SW: 8P0 919 283 HW: 8P0 919 283
    Component: Parkhilfe 4-Kan H06 0020
    Coding: 0000003
    Shop #: WSC 06435
    Address 7D: Aux. Heat Labels: 1K0-963-235.LBL
    Part No SW: 1K0 963 235 C HW: 1K0 963 235 C
    Component: PTC-Element 0404
    End --------------------------------------------------------------------------------------------------
    Any ideas on what could cause the problem?
    Thanks in advanced
  2. mike foster
    3,967
    All your faults refer to one code - 01314.
    This is the RossTech page showing possible causes. It seems to be associated with communication between modules and stored faults. Follow the instructions and see if it solves the problem. If not then the dealer may be right !
    01314 - Ross-Tech Wiki
    Good luck !
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    first get yourself a vcds cable next perform the basic adjustment for levelling, if this doesnt work then id check the output of the level sensors with a multimeter, if they are working then change the unit yourself theyre cheap on ebay.de and its an easy fit
