A3 8P Headunit and Speakers
Crisis Aug 10, 2007
  1. Crisis
    Crisis Member
    93
    Right,
    Got myself a Single DIN HU (from last car)
    Getting the Fascia Adapter (classified on here)
    How do I get the old unit out, wire up etc. Anything I should know? Can't find a guide on here.
    Also:
    Speakers, what Alpine components would be a simple direct swap?
  2. SamDude
    SamDude Active Member
    2,102
    Dude - if that's your car in your signature, its not a Sportback...
  3. Boydie
    Boydie Guest
    the car in his sig is a photoshop and I posted it up weeks ago :p
    What type of alpine components are you thinking about?
    Audi concert uses Blaupunkt speakers which in my opinion for a standard system is very good - I upgraded though to focal kp2 6.5" components so if you are definately wanting alpine I hope you are opting for Type x or F1's and a decent amp to power them!
  4. Crisis
    Crisis Member
    93
    Okay, maybe I'll leave them STD then. Im throwing in an Alpine 9833 headunit 4x60W.
    It is indeed a photochop, but a nice one at that! Any basic recommendations?
  5. Boydie
    Boydie Guest
    recommendations for what?
  6. Crisis
    Crisis Member
    93
    ICE upgrades in general. Sounds like the speakers should be left alone. I've got my Alpine 9833 going in.
    Anything else that should be done?
  7. Boydie
    Boydie Guest
    depends what you want from your music -I completely changed my whole system and put in top end focal components, diamond D6 10" sub, audiocontrol EQL and 2 genesis amps along with the becker head unit
    to say the sound quality is awesome is an understatement! its un-fecking-believable!
    but i have been messing around with sound systems for 6years now so I am always after quality and stock systems just do not do it for me (even though the A3 one is the best ive heard in a standard car)
    I would definately get a phone kit in the car anyway as there is no excuse these days not to have one
  8. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    You are going to need to supply an ignition switched supply to the HU and the stock system is power up by a CAN-BUS command when the ignition is switched on. The stock loom will only have a perminant power feed and earth connection.
    Paul
  9. Crisis
    Crisis Member
    93
    I have myself a phone kit.
    I've found the existing unit is quite good but without MP3 compatability the CD collection in car is rather excessive.
    I'll try the Alpine, see if its worth keeping I suppose.
  10. Crisis
    Crisis Member
    93
    So with the Fascia on its way I've found:
    Stock is 4 x 20W + 40W Amp
    So now I'm going to be:
    4 x 60W + 40W Amp
    Where is the "Active Amp" cause I'm sure its going to be a bit underpowered now with the Alpine CDA-9833R.
    Otherwise: Which Audi HU plays MP3s?
  11. Crisis
    Crisis Member
    93
    Anyone have a guide on fitting a headunit in the 8P?
    Or anyone know if a stock Audi unit will directly replace and play MP3/WMV CDs?
