A3 8P 2005 - Head Unit Upgrade - Single Din - Concert Replacement - KDC-BT92SD
Novocaine Feb 17, 2013
  1. Novocaine
    Novocaine New Member
    17
    Hi,
    I've done a bit of searching about this but I'm slowly becoming more and more confused..
    I'm trying to replace the stock Concert signal DIN head unit with a Kenwood KDC-BT92SD in my 8P 2005 A3.
    It started out looking like a straight plug and play job but that soon turned into a nightmare [​IMG]
    I've plugged in the two standard adapters and also connected power to both the Red and Yellow leads but If I understand correctly I need an wiring adapter to plug in the long adapter?
    There was a yellow plug that seems to connected to the aerial lead which I presume also needs to be connected? as I currently have very poor FM reception.
    What I really want to know is what components / adapters do I need to purchase in order to:
    1) Get a Radio Single
    2) Have the unit power on and off with the ignition
    3) Connect the long plug (sub?)
    So after some more reading I think I need the following?
    http://www.connects2.co.uk/images/pr...w/CT27AA05.jpg - VW/Audi/Skoda/Seat Aerial amplifier
    http://www.connects2.co.uk/images/pr...w/CTSAD003.jpg - Audi CAN-Bus Steering Wheel Control Interface
    Appreciate your help and apologies again if this has been covered many times.
  2. AndyMac
    9,832
    45
    Yes those are what you need
  3. Novocaine
    17
    Thanks for the quick response Andy.
