Hey there,
Kindly help with some pics to show where I need to get into to remove my front door panel to get to the speakers.. just cant seems to find the holding clips or screws!
There are two screws at the top... one at the front of the door and one at the back (black with a screw cup)... then look at the door handle... there is one screw holding on a black cover (inside the handle facing to the back), remove this cover and undo the two screws behind it...
Lift the whole door panel up then tilt back... everything should be obvious...
